drive shaft difference???
ruffryder
Is there a difference between 6pot and 4 pot rear drive shafts the side that goes to the diff.... the one came out had curved centre and the one I'm trying to put in is bait flatter ... any help would be great
Rtaylor2208
As far as I am aware the only difference is those fitted with ABS to those that do not.
Jim320i
- E30 Zone News / COTM Team
As above, the only difference in drive shafts is ABS & non ABS. There is no difference in 4 & 6 pots drive shafts
ruffryder
Thanks for reply... would the diffence be on the diff side??
ruffryder
capnmchl
The ABS rings are on the outer joint closest to the trailing arm/hub.
ruffryder
Ok.... so why have i got two different drive shafts ..... everything the same expect the side that connects to the diff...
Rtaylor2208
Do you mean on the car? Or you have two shafts, one of which might not be for an E30.
- **BANNED**
Three shafts connect to the diff;
Propshaft(1)
Driveshaft(2)
Be helpful to know just what the OP is refering to.
Propshaft(1)
Driveshaft(2)
Youth is wasted on the young.
ruffryder
Sorry not made sence.. right i got a tourer with a m30 3.5... My rear drivers side drive shaft has broken from the part that joins the diff... now i got a e30 drive shaft that won't fit because the end is different from the one i've taken out... only the end to the diff... it don't fit in to the diff flange ...
Sanchez
is the spare shaft the same as the broken one?
Grrrmachine
- E30 Zone Wiki / Team Member
What diff are you using?
ruffryder
@ sancez if the spare was same as broken one I wouldn't have a problem....
@ grrrmachine I been told its a m3 diff.
I would really like to get this thing on the road.. been to long sitting aside!!!
Sanchez
So if its not the same it wont fit!!!!!!!ruffryder wrote:@ sanchez if the spare was same as broken one I wouldn't have a problem....
Theres your problem.
ruffryder
The question was what's the difference as my spare came off a e30...not why my driveshaft won't fit. its a bit obvious it won't fit if its not the same as original... so bit of a silly answer .... unless you know what one i need keep your comments to yourself... not very helpful
Grrrmachine
THe point is you've given us nothing to go on. There are no differences between driveshafts, and it's only after 12 posts that we find out you're not using a standard E30 diff. You've not provided any pics, so we're all just shooting in the dark.
Help us help you, and stick some pics up of what you've got if you want sensible answers.
