Brake pipe flaring kit.
Demlotcrew
Can anyone recommend a decent Metric double flare (BMW Style end flare) kit?
Cheers gents.
Andrew
Cheers gents.
Andrew
Demlotcrew
Demlotcrew
Or are the BMW pipes finished with a bubble Flare?
http://www.ebay.co.uk/itm/FRANKLIN-TOOL ... 20d23d35c0
scallyally
Yep, Bubble flare is correct. Check out RTSAUTO.com for instructions.
Demlotcrew
Brilliant! Thank you
maxfield
The second one is the same as I've got.
They are a very good tool.
Demlotcrew
Does it mark the pipe at all?
I wont be using steel pipe so I think this will last for a full set of flares?
maxfield
Does leave very little marks on the pipe but unless your an inch away you wouldn't notice.
I take it you'll be using kunifer?
Had my tool well over a year now and don't plenty of flares and they're still perfect.
Demlotcrew
Cool cool, im using a hard anodised aluminium pipe, never thought about Kunifer!
chh137
You would be better off with tool that does both types of brake pipe flare( concave and convex . op1 and op2) Then You could do both types of brake pipe end to fit 99.9% of cars.
Demlotcrew
True, but the double flare is not the same as a bubble flare and wont work, I have used these hand held ones before and they didn't do the flare anywhere near as nice as the BMW factory pipes.
I think I'm going to play it safe and go for the bubble flare in my second link.
Andrew
Andrew
maxfield
You could always put some tape around the pipe stop it marking it.Demlotcrew wrote:Cool cool, im using a hard anodised aluminium pipe, never thought about Kunifer!
Nelly
- Gumbo
beemerbird
LolNelly wrote:lol, still as anal as ever i see.
Not seen you around for a looooong time
