Squeaky Rear
Mo13
Thu May 30, 2013 6:38 pm
Everytime i go over speed humps i hear squeaks coming from the rear suspension - can anyone advise what it could be?
Cheers Mo
capnmchl
Thu May 30, 2013 6:45 pm
If you bounce up and down on the rear of the car, does it do it?
Or jack the car up, and then use the jack to move the trailing arms, being careful not to lift the car off the stands.
If anything though, I'd have to go with the anti roll bar bushes.
Tommek
Thu May 30, 2013 6:47 pm
it could be the rear shock top mounts or a rubber bushing ... something.
E30 Touring
Mo13
Fri May 31, 2013 12:17 am
When bouncing the rear I can hear a hiss from the rear shocks. When in the car I hear the same but addition to that when ever I go over a pot hole or uneven road surface I can hear squeaking, something that sound like rubber rubbing against rubber I have power flex subframe bushes and trailing arm bushes could those be it?
Fri May 31, 2013 9:50 am
Mo13 wrote: I have power flex subframe bushes and trailing arm bushes could those be it?
You put this rubbish on and wonder why it squeaks??
Mo13
Fri May 31, 2013 3:32 pm
lol i guess its them then....... :o:
I havnt heard anyone else complain...is it normal then?
Fri May 31, 2013 7:20 pm
A natural reluctance of people to admit in public that they've fallen for advertising spiel and wasted their money?
Mo13
Fri May 31, 2013 7:54 pm
Ahh thanks I shall look on to changing them back at some point then.
Now ill just crack on with the rest of my list
harry_p
Fri May 31, 2013 8:49 pm
Must be the trailing arm ones squeeking then because my poly rear beam mounts have been on for seven years and don't squeek.
cheers,
harry
capnmchl
Fri May 31, 2013 10:13 pm
It'll be a rotating part that squeaks. Anti roll bar bushes are prime for it, and the trailing arm bushes could be a culprit, especially being poly bushed instead of rubber.
