M20B28 engine help
aceifty
Hi all, some of you may remember my B28 dying last yr, well the autopsy and rebuild has know begun. heres a recap of my spec and what happened.
built a B28 using the m52b28 crank, M20B20 rods, 2.5 pistons. head has a newman 290 cam, ss manifold and exhaust. she was running fine and well like this no issues at all, year later replaced the head as mine had the typical M20 crack, and put on a BBTB at the same time. again she was a amazing drive then about 4-6 weeks later it all changed. she just packed up on me. we found a broken spark plug (never seen one like that before EVER). youl find a pic here on the original post
so know ive started ripping it all apart. piston 2 is obviously no longer a piston and had a exhaust valve stuck in it. the rest all look fine, however they all had some metal shavings/fillings on top of them.
on the head inlet valves from chamber 2 onwards all are bent or something is keeping them open very slightly. chamber one all looks to be fine.
i had thought it might have been the timing but it was 100% using the original m20b25 timing marks. the timing was checked about 3 times by me and my brothers.
im lost as to why this would have happened. i want to know why to avoid this happening again. hope someone can help
- E30 Zone Meets/Events Team
Did you do a squish test on the build to see how much clearence there was between the valves and pistons?
aceifty
no i did not and the car did run fine for just over a year apart from a rocker arm breaking.Rav335uk wrote:Did you do a squish test on the build to see how much clearence there was between the valves and pistons?
Did the belt slip??
gooner1
- Out humping Reindeer
Would the original Timing Marks be applicable, considering the Cam you used?
aceifty
no it did not that is what i had thought.Rav335uk wrote:Did the belt slip??
aceifty
from what i was told the original markings will be fine.gooner1 wrote:Would the original Timing Marks be applicable, considering the Cam you used?
aceifty
this is the newman cams spec sheet i had used the 290/290 cam
http://www.newman-cams.com/pdf/bmw.pdf
hopefully some on here can make sense of it as i don't understand it
aceifty
im still thinking if it was a timing issue it would have happened a long time a go not after 12 months
maggspower
- Turbo Farmer Tractor Driver
Sounds like a stuck or dropped valve.
Stuck: obvious really, gets held open, piston hits on the upstroke.
Dropped: either the valve becomes detached, or the head of it comes off.
Any debris floating about in one cylinder can migrate its way around to any of he others, via the inlet valve, inlet manifold, then another inlet valve
Pm on its way.
Pm on its way.
Contact: theengineshedonline@gmail.com
aceifty
could it be that the valve snapped, the debris from it moved to the others, and also got caught on the inlet seats causing the compression to leak through them? meaning the whole engine dying would be down to one valve snapping?maggspower wrote:Sounds like a stuck or dropped valve.
Any debris floating about in one cylinder can migrate its way around to any of he others, via the inlet valve, inlet manifold, then another inlet valve![]()
Pm on its way.
Not bad prices either, ooked at the M30 ones.aceifty wrote:this is the newman cams spec sheet i had used the 290/290 cam
Byrons right, it looks to be a broken valve.
aceifty
yh there good cams, newman are a very good manufacturer aswell, and i did enjoy that cam.
there is a broken exhaust valve on number 2
maggspower
Yes, that exactly.aceifty wrote:could it be that the valve snapped, the debris from it moved to the others, and also got caught on the inlet seats causing the compression to leak through them? meaning the whole engine dying would be down to one valve snapping?maggspower wrote:Sounds like a stuck or dropped valve.
Pm on its way.
aceifty
so know just need to know why the f**k the valve snapped!!
My bets still on the belt slipping.
aceifty
so was mine but before i took it all apart the timing was spot on, not a tooth was off
Rav you f****** cowboy! If it was the belt it would have taken more than one valveRav335uk wrote:My bets still on the belt slipping.
Come on then Mr expert.
Rather than taking the time to.post having a go at me lets have your input to the problem.
Your a bit touchy tonight
Not at all.
I want to see your answer.
aceifty
here are some pictures of the damage.
the first thing i had found was number 2 spark plug, the other bit came out the exhaust.
i had put in another spark plug before removing the head and it had got jammed in. the spark plugs at first where a bitch to open.
picture of the head
and finally pictures of the piston.
picture of the head
macas
Fook me!!,i have never seen a sparkplug with that damage before!
leeparkes
macas
^^^^yep ,id say thats exactly whats happened to this chaps engine
leeparkes
I still have the piston, on display in my man cave.
maggspower
The main thing to remember now is before you rebuild the new engine make sure there is nothing left in the inlet or exhaust manifold!!!!
?Needs to be machine cleaned.
simple valve failure then.
maggspower
Yes I would say get a pressure washer in it at leastRav335uk wrote:?Needs to be machine cleaned.
At a best guess I would say yes, but I would be checking the inlet tract for clues. Its rare for fatigue to get the valves as they are made from high grade steel, but it does happen.
Maybe high revs would cause this without the proper balancing of engine components.
aceifty
as im using a 290 cam would the standard valve springs be up to the job
1989 cab M20B28 build
maggspower
It depends how high the engines red line is set, and how often its used. The correct valve springs are, the lightest poundage to remain in control of the valve and combat valve float at the highest revs that the engine is designed for. Valve float is when the cam and valve spring are no longer in control of the valve, it will bounce off its seat and is generaly bad for an engine. It can feel like hitting a rev limiter. IIRC the standard springs in good condition are good for 7000rpm.aceifty wrote:as im using a 290 cam would the standard valve springs be up to the job
Too strong a spring, leads to premature wear, and BHP loss in frictional forces.
How much extra lift is quoted on the cam?
aceifty
iv put a newman cam spec link on page 1 if it helps, i looked at it but got lostmaggspower wrote:It depends how high the engines red line is set, and how often its used. The correct valve springs are, the lightest poundage to remain in control of the valve and combat valve float at the highest revs that the engine is designed for. Valve float is when the cam and valve spring are no longer in control of the valve, it will bounce off its seat and is generaly bad for an engine. It can feel like hitting a rev limiter. IIRC the standard springs in good condition are good for 7000rpm.aceifty wrote:as im using a 290 cam would the standard valve springs be up to the job
aceifty
im thinking of going up in size of the valves, will i notice much difference
i know the head will need some work to take the valve, but am i write to say the pistons will need work as well.
maggspower
The only way to know for sure is to do a dummy build. You have a cam with a higher lift, and a valve with a larger diameter and a head that will have had a skim, it would be a brave man that told you that it would be fine, without checking.aceifty wrote:im thinking of going up in size of the valves, will i notice much difference
