Hi Chaps,
When driving my car around corners, it seems to feel like its floating a bit, i've a quick check underneath and can't see anything dodgy. Could it be my steering linkage at all?
Light Steering
Pal318is
Pal
[img]http://
[img]http://
- **BANNED**
'er indoors always moaned about 'heavy steering',so I guess I have the wrong E30's!
On a more serious note,though,pop the bonnet and examine the steering shaft guibo mounted on the exhaust side of the engine.These rubber/fabric couplings have a nasty habit of falling apart after 20 years or so and can lead to odd steering response.Get a helper('er indoors is perfect)to waggle the steery wheel whilst you look at the coupling,you need to see no free play whatsoever.
The fix is both simple and almost cheap,a new rubber quibo from your local stealer and four of the special,shouldered bolts to replace the rivets that hold the original in place.
Youth is wasted on the young.
Pal318is
Top man Malcolmdaimlerman wrote:'er indoors always moaned about 'heavy steering',so I guess I have the wrong E30's!
I got a feeling it could be this mate, appreciate the advice. I've noticed that my steering feels a bit wobbly at times and it veers to the left too
Pal
[img]http://
[img]http://
capnmchl
Check your tracking and tyre pressures.
Pal318is
Cheers bud, just got some new front tyres, need to get it tracked this weekend tbhcapnmchl wrote:Check your tracking and tyre pressures.
Pal
[img]http://
[img]http://
capnmchl
Yeah. Make sure the tyres guys haven't just whacked up the pressures to get the bead to sit and then not corrected them.
If the tyres are right, then the tracking is the next easiest thing.
