Should all rust be treated by removing it altogether and replacing a section of metal, or are there other ways which may be appropriate in some situations?
I have seen all kinds of rust 'prevention' and 'curing' products such as Por15, Corrosion block, through to 'electronic rust prevention' and 'cold galvanizing rust curing', but am I not right in thinking that rust is simply a chemical reaction which will spread irrespective of what you slap on it, and that these various putties and sprays will only slow it down?
How much will proper rust repair cost? (i.e. cutting away the affected area, fabricating a replacement section, and welding it in place etc) I'm sure it will depend entirely on the extent of the problem/size of the section and various other factors, but if you had to give me a general estimate? Something like in the M3 sticky thread at the top of this section for example.
I have no physical example of what I mean, this is just pre-purchase talk so I can get a general idea of the cost involved in repairing the rust on an E30 if and when I come to purchase one, and what kind of rust should make me shake my head at it and walk away.
Thanks all once again
*edit* oh and also, what is the best way of preventing new rust damage once the existing rust is all but gone?
