Rear wheel bearings?
samuraibaz
are e30 rear wheel bearings all the same across the range??? cheers all
TPS
I think it depends if you've got ABS or not.
GDBN
Think that's the fronts ....
Rears are the same, apart from M3 and maybe the 4 wheel drive.
G
G
I deserve 6 of the best ...
Andy325i
I thought 4cyl were different to 6cyl when I was playing with compact arms. Was years ago though lol
Andy325i
May be a drum/ disc thing. 325i ones are the same as M3
GDBN
Think they are different depending on if you have rear discs or drums ... sorry.
G
G
Automaton
Have got a pair of bearings from a dealer who didn't check against the VIN.
Have got front bearings that have teeth that are apparently for an ABS model. He is insisting that it will fit my non-ABS, front disk brake and rear drum 1986 316.
Now I'm wondering the same about the rear. It's a non-ABS drum unit. Will the round smooth bearing provided fit? Are they standard as he claims?
Maneesh
1986 E30 M10 316 Manual Schwarz Chromie
1982 E28 M20 520i Henna Rot - Project
1988 E32 M70 750iL Schwarz - MASSIVE Project
1991 W201 190e Automatic Schwarz - Sold
1991 W201 190e Automatic Silver AMG Tribute - Sold
1993 E36 M40 316i Manual Brillantrot (RIP: rotting in peace)
Join other Carb Fanatics: E30 316 Carb - The Faithfuls https://www.facebook.com/groups/444263742439145/
- **BANNED**
I'm running the same type of front wheel bearing on both of my E30's.One has ABS(touring)and one does not(cabbie)
Not,yet,had the deep joy of changing rear wheel bearings...
Youth is wasted on the young.
Automaton
Arrgh. Confusing.
Do you have pictures or a link to a post somewhere?
Maneesh
- **BANNED**
Sorry.
The toothed type will fit and work fine.
There's probably a hole in the strut to take the ABS sensor in your non-ABS car as well!
Automaton
Superb.
Thanks for that. I will check with the garage if they have missed something when they informed that it won't fit.
Is there an accessory or a convertor required to fit the 'toothed' bearings instead of a smooth original bearing? the size and shape is quite different.
Maneesh
capnmchl
Front bearings with the ABS rings will fit a non ABS E30. I know because mine is exactly the same.
Having not owned an ABS E30, I can't be sure on the rear, but I get a feeling the rings are on the drive shafts and therefore it doesn't matter what type of bearing you receive.
GDBN
There are no teeth on a rear bearing. The front is a complete "hub" unit with ABS or not.
The rear is as stated ... just a bearing and nothing to do with ABS.
G
G
Automaton
Cool.
That saves me a lot of trouble. Because I had got the bearings from Thailand. Couldn't post them back because of the weight.
The front shocks too were fatter than what the shock body would accept. So stuck with those
Trying to see if a local shop will swap the Sachs shocks with thinner ones.
Lesson: Never buy any car parts from a shop where you need to show pictures to make them understand what you need.
Maneesh
- **BANNED**
Front struts came in two sizes,45mm and 51mm.
Only 325i saloon came with the bigger units from the factory,but all cabbie/tourings came with them.
I guess from your location you are playing with either a 4 cylinder car or perhaps a 320i?
Automaton
Yes, you guessed right.
It's a 316 saloon.
Imported to India, they were never sold here. And as far as I know there are a TOTAL of 8 or 9 E30s surviving in India.
I have the least desirable cousin, a carbureted M10 version. But I am happy i got what I had been searching for, for over 5 years!
It's a 316 saloon.
Maneesh
