m20 hot starting issue
initial_g
E30 Zone Moderator
E30 Zone Moderator
Post Sun May 26, 2013 12:15 am
My m20b25 is haveing starting issues when warm. Ive had the inlet off and replaced all the gaskets with new ones cleaned up the tb and the maf sensor, it starts perfectly when cold but when warm... even after it just idleing for 5 mins from cold .. switch it of then it wont restart :/ any ideas? Cheers g[/list]
Morat
Post Sun May 26, 2013 7:10 am
How is your fuel consumption?
jimbom30cab
Tech 1 freak
Post Sun May 26, 2013 7:18 am
Is it worth testing the blue temp sensor for resistance readings? The wiki has a guide iirc.
mark_i
Post Sun May 26, 2013 7:53 am
main relay (white) and ECU relay (orange) can cause the warm starting issue
initial_g
E30 Zone Moderator
E30 Zone Moderator
Post Sun May 26, 2013 8:59 am
Ive not driven it yet so not sure on fuel consumption. Its not been run in 2 years....
Grrrmachine
E30 Zone Wiki / Team Member
Post Sun May 26, 2013 9:34 am
If it's been sat for two years then the ECU won't have any of its idle settings sorted and is probably massively overfuelling.
I posted this elsewhere yesterday:
Grrrmachine wrote:After resetting the ECU, FROM COLD start the car up and let it idle for ten minutes. Then turn it off, restart, and take it for a very aggressive drive.
You should still test the blue temp sensor at the ECU plug though, to make sure the signal's getting through.
initial_g
E30 Zone Moderator
E30 Zone Moderator
Post Sun May 26, 2013 9:34 pm
Cheers guys ill try your pointers and see how it goes.... I have had the ecu out when I had ther dash out..
