refurbing engine parts
polsta
Post Tue May 21, 2013 7:58 pm
the thermostat housing and throttle body, whats the best way to refurb them ? is it just vapour or soda blasting ? whats best ? anything else that can be done ?
if anyone on here can do them, send me a pm
jimbom30cab
Tech 1 freak
Post Tue May 21, 2013 9:47 pm
I got mine done at a little company under the itchen bridge, they are brill. They were vapour blasted which is high pressure water, see my m30 thread for the results.
http://www.trestanfinishers.com/
I can't recommend them enough, proper old school engineers, amazing attention to detail also. Cash and cheap also.
Cloggy Saint
Post Tue May 21, 2013 10:00 pm
There's no substitute for elbow grease. I did my inlet, TB and thermostat housing with a dremel and wet and dry, finishing with a fine wire wool.
Media blasting will get them clean but won't give them a shine.
polsta
Post Tue May 21, 2013 10:11 pm
jimbom30cab wrote:I got mine done at a little company under the itchen bridge, they are brill. They were vapour blasted which is high pressure water, see my m30 thread for the results.
Nice one jim, how much did they charge ?
Cloggy - that engine looks great, mine will come out in the winter for a full sort out like that, I need to get a dremnel, is it just 1 tool in it that shines them up like that ?
Cloggy Saint
Post Tue May 21, 2013 10:13 pm
I started with a dremel with wire wheel attachment which cleans it up nicely but obviously scars the metal. I think I started sanding with 120 wt and dry, working up to 2000 and then the wire wool. The TB was quite quick and easy to do, the thermostat housing less so!
jimbom30cab
Tech 1 freak
Post Tue May 21, 2013 10:15 pm
its cheap, i left a large batch of stuff and it was a £100 - see my m30 thread mate
dremnel - pop over to B+Q in Havant and have a look at them - well well worth the ££ IMO - i use mine all the time mostly with a little cutting disc on
capnmchl
Post Tue May 21, 2013 10:17 pm
There are drill attachments that are like wire wheels but are made of plastic strands instead. They seem to work really well on aluminium.
http://www.toolstation.com/shop/Power+T ... d80/sd1920
The last 3 on that page
Kedge
Post Tue May 21, 2013 10:27 pm
I think just blasting looks best and is closest to the factory look, I'm not a fan of shiny engines. I'm toying with the idea of trying a clear powder coat over a few bits after blasting to see how that looks.
Instagram - Kedge85
polsta
Post Tue May 21, 2013 10:29 pm
Cheers guys il look in to the dremmel there's a few tools I need, once the cars re built il hve loads of space to kit the garage right up, cloggy I don't quite fancy too much niggly work with sanding bits like that,it mullers your hands lol
Jim what page is it on ? Any chance you can post a link here I'm on fone at work so bit of a ball ache and data heavy to scroll through all the pages with images , interested to see what else you it done
Can the amf be done ? Or can it not be separated or shouldn't be meddled with ?
polsta
Post Tue May 21, 2013 10:32 pm
Also a question - has anyone done or got an idea of a cost to replace all the engine pipes and hoses ? I might maybe label and remove them all and give a good clean whilst its all apart
Rtaylor2208
Post Tue May 21, 2013 10:44 pm
All the coolant pipes, minus the metal cross pipe that goes behind the fan are just over £100 from the dealers. The vacum pipes are way more expensive. If you have the two pipe setup that goes from the servo to the TB its over £100 on its own. Add that to the rest and it starts getting pricey.
Cloggy Saint
Post Tue May 21, 2013 10:48 pm
polsta wrote:Also a question - has anyone done or got an idea of a cost to replace all the engine pipes and hoses ? I might maybe label and remove them all and give a good clean whilst its all apart
Old hoses can be bought back to life by gently rubbing the crusty outer layer away with some fine wet and dry.
SteSE
Heading for the Naughty Room
Post Tue May 21, 2013 11:04 pm
I would replace if they are looking old and crusty. Last thing you want is an old perished coolant hose to burst.
87.5 Impact FM
PS3: gary_bunter
1986 325i resto - M52'd
C plates are fastest
Cloggy Saint
Post Tue May 21, 2013 11:06 pm
I'm not talking perished or damaged, just surface gunk and where they've faded.
spook
League two here we come !!!
Post Tue May 21, 2013 11:08 pm
Cloggy Saint wrote:There's no substitute for elbow grease. I did my inlet, TB and thermostat housing with a dremel and wet and dry, finishing with a fine wire wool.
That looks spot on :cool:
SteSE
You said crusty, crusty = old and perished.
Why take a chance on something of little relevant cost that can potentially cause a break down?
87.5 Impact FM
PS3: gary_bunter
polsta
Post Tue May 21, 2013 11:15 pm
Mine arnt old perished or crusty, a bit faded and grubby but no splits or light cracks, but there are a fair few pipes in there once the inlet etc is removed, hence the price question, but its then remembering them all, I might get a load if jubilee clips, then maybe do pipe by pipe and re fit, with a big bucket if soapy water, wet dry paper and rubber treatment ?
Cloggy Saint
Post Wed May 22, 2013 5:47 pm
SteSE wrote:You said crusty, crusty = old and perished.
I'm not taking a chance with anything. All hoses were checked and in good nick, just crusty, which in this context = discoloured and dirty.
polsta
Post Wed May 22, 2013 8:18 pm
had a look at the pipes today, its all in pretty good order,a good clean up will show more, all i could find was some cracking in the fuel filter pipe,and some cracks,that bent in to splits, in the bottom air filter box rubber boot, so ordered a new one
tonight at work im taking a couple of bits and some essentials, to have a polish up on the top bit afm, whilst im getting paid for it 8)
pukar
Post Wed May 22, 2013 8:56 pm
if you want a factory look, get it all nice and shiny
.....then coat it in a layer of yellowy wax that becomes impossible to clean off! :mad: :wink:
Sjoerd320i
Post Wed May 22, 2013 10:36 pm
When is it going in Ed? :wink:
Let me know when I need to order some parts for you eh!
Cloggy Saint
Post Wed May 22, 2013 10:54 pm
Sjoerd! I was going to give you a call in the near future, I got your number from your wanted ad on Marktplaats. Did you get any seats?! I'm going to England on Saturday and will pick up the last couple of bits there and then apart from a few small jobs it's pretty much good to go. I'll let you know, cheers :)
Sjoerd320i
Post Thu May 23, 2013 9:45 pm
No problem mate, got layed off work so I don't have much on my hands the next 5 weeks.
You can always give me a call. No seats yet :( probably will be buying a new upholstery set.
Cloggy Saint
Post Thu May 23, 2013 9:48 pm
Bad news about the work, what's your business?
I'll definitely gove you a call in a week or 2 :thumb:
Sjoerd320i
Post Thu May 23, 2013 10:22 pm
Yeah sucks big time but I'll work something out. I'm a carsalesman at Ford. Just had a job interview today, will hear the outcome tomorrow... Fingers crossed :roll:
