Gauge of steel
bimanut
Post Sun May 19, 2013 5:08 pm
Booked a week off work the begining of next month to attack the welding on my project car,which consists off both front footwells the bottoms of the front arches behind the headlamps.
Can anyone tell me what the thickness of the floor pan steel is?
retroboyo
Post Sun May 19, 2013 6:19 pm
I used 1.5mm as it was the floor as it was recommended to me by someone who did it. I have seen peeps use thinner though.
Post Sun May 19, 2013 6:21 pm
0.8mm is the norm I think
freeflow
Post Mon May 20, 2013 9:04 pm
you wont go wrong with 1mm,its easy to get from stockists being a common size, expect to pay around £25 for a 8x4 sheet,if they cut the sheet into a smaller size its more expensive.
cheers Keith
www.questmotorsport.co.uk
Made in England not bought in England
where ever possible
Neilios
Post Mon May 20, 2013 9:25 pm
I would use either 1mm or 1.2mm for most body related repairs.
bimanut
Post Mon May 20, 2013 10:36 pm
Thanks all,
will go for 1mm i should be able to order some through work and cut it down into smaller pieces on the gilly 8)
Post Mon May 20, 2013 11:20 pm
For nearly every repair I've made on every shell I've worked on; the thickness of an E34 bonnet.
maxfield
Post Tue May 21, 2013 9:51 am
I always use 18gauge, which is 1.2mm.
Morat
Post Tue May 21, 2013 10:08 am
Brianmoooore wrote:For nearly every repair I've made on every shell I've worked on; the thickness of an E34 bonnet.
I'd imagine that's pretty thick?
Post Tue May 21, 2013 2:13 pm
Never measured it, but it seems about the same as what I'm repairing in most cases.
bimanut
Post Tue May 21, 2013 5:10 pm
The last one i did i used door skins and part of a rear quarter panel but thats near enough gone,
hence the question :)
billgatese30
Post Tue May 21, 2013 5:20 pm
anything of approx 1mm is going to be good enough to get it through an MOT if you want a cheap fix, and should still be easy enough to bend/fabricate to the shape you need. If you want perfection then easiest thing to do would be to get measuring :D
