battery relocaton kit
polsta
Post Thu May 16, 2013 11:26 pm
encountered an issue- i dont seem to have the bracket that holds the battery in place in the plastic tray in the boot relocation kit , what exactly holds it in place ?
what is part 13 ? is it a metal/plastic piece or some sort of strap ?
part 8 and 9 , its not listing it, 7 is available, whats 7 ? it is available, will that alone hold the battery in place ?
or can anyone help with the bits i need ?
bmw9818
Post Thu May 16, 2013 11:44 pm
on mine i got a normal clamp, it was the same one as I had up front, theres a threaded hole in the battery tray for it to clamp down and secure,
no 7 looks like the one,
Post Fri May 17, 2013 6:35 am
You only need No 7. I've never seen that strap.
gaszman
Post Fri May 17, 2013 9:33 am
i have the same
harry_p
Post Fri May 17, 2013 12:24 pm
my m3 just has a number 7 at the back of the battery, the front edge slips under a ridge in the tray, so the single clamp bolt at the back will have no problem holding it in place.
cheers,
harry
polsta
Post Sat May 18, 2013 5:39 am
Nice one Cheers, ordered them up it was £17 odd for the 3 bits !! But more than the sites say
jimbom30cab
Tech 1 freak
Post Sat May 18, 2013 6:44 am
Worth doing as its an MOT advisory for an insecure battery
polsta
Post Sat May 18, 2013 6:59 am
I don't know if there was one in there before , but in the tray were 2 rusted bolts , but got a nice replacement
Jim do you have the inner arch impact protection bit ? That was only a fiver from snows its a nice piece
jimbom30cab
Tech 1 freak
Post Sat May 18, 2013 7:34 am
Yes I have that thanks mate
