spacca bolts
Post Fri May 17, 2013 7:05 pm
took the car out today and noticed a rattle from the back then tracked it down to this....
these are oem rear damper bolts and as you can see they are too small for the bush hole in the spax adjustable shocks and even fully tightened there is movement :mad:
i've put a washer either side of the shocker and tightened up with a long bar for now but i know the rattle will return sometime .
has anyone else had the same problem and do spax sell the right bolts or where can i get them from :?
p1ssed oFF! :evil:
Post Fri May 17, 2013 7:34 pm
SPAX, that is your problem Mick ! :(
maxfield
Post Fri May 17, 2013 7:45 pm
I've had this with shockers before.
Luckily I have a good engineer has machines some sleeves in the past.
Post Fri May 17, 2013 7:55 pm
maxfield wrote:I've had this with shockers before.
great idea ,i'll see my flywheel man and see what he can do 8)
i bought these dampers from another zoner with no mention of this problem,they were only fitted to his car for a short period of time...no wonder,the f00kin arsehole must of known about it :roll:
Post Fri May 17, 2013 8:11 pm
bin the cheap sh!t I say. Nowt wrong with tut bolt.
85Nm iirc
Post Fri May 17, 2013 8:23 pm
£77 each new isn't that cheap but £50 as new was .
the boge turbo's i had were too soft for my liking so i'll get some sleeves made up for now.
i want to change the fronts which are also boge turbo for something a bit firmer but not rock hard that i can use with m-tech front springs so don't want shortened dampers .
any recommendations ?
ross_jsy
Post Fri May 17, 2013 8:41 pm
Can't go wrong with Bilstein B8's.
Nothing wrong with Spax PSV's, I have them on the rear as well and they are a decent shock, just not zone vogue it seems.
NOT SPAX ! The Clifford of the shock absorber world ! shudder :(
Post Fri May 17, 2013 8:50 pm
ross_jsy wrote:Can't go wrong with Bilstein B8's.
are the b6's the shorter ones ?
age
Formerly twist316
Post Fri May 17, 2013 10:33 pm
no b8 is the shorter one mick
M40 rightness if you can get to 6000rpm noone can hear your tappets
Post Fri May 17, 2013 10:39 pm
so b6 will be good with m-tech springs .i don't want to lower my car at the front any more than that .
MattTheHat325
Post Sun May 19, 2013 3:53 pm
That will work well mick, I've got b8's on mine and they are just awesome. They may be a bit harsh for some, more so if you are on low springs, but they perform fantastically.
Post Sun May 19, 2013 5:59 pm
age wrote:no b8 is the shorter one mick
Wrong, and before anybody starts posting links I speak from actual experience, not internet searches :)
Post Sun May 19, 2013 6:07 pm
b6'S ARE shorter ala OE tech 1 sport fitment.
Spax just don't last they are horrid.
MattTheHat325
Post Tue May 21, 2013 1:59 pm
Do the b8's have shorter travel then dan? I've never had b6's to compare but I've got 60mm springs on mine with b8's and its really composed. Are they just a stiffer shock?
