We're dropping an M30 (3.5l) engine in an E30. Got the engine in the car and just sourced the last of the parts we need to get her up and running (exhaust manifolds and prop).
The last thing I need is a set of exhaust manifold gaskets. Found a few but they're all in the states or Oz. Do any of you know somewhere I can source a set in this country?
Much appreciated.
Syko
Exhaust Manifold Gaskets
leeparkes
GSF or Europarts.
Bristol_Jer
Make sure you get ones with the heat shields for the ignition leads as part of the gasket, same as the genuine ones, I've seen some cheaper ones for sale that don't have a heatshield on them.
Sykopaf
Ok cheers lads
