FRONT DOOR LOCK.
AndersLS
Post Tue Jan 03, 2006 9:50 am
Hello forum...is it easy to repair a defective front door lock?
The central locking works...just not when you use the "main" door.
Any help would be appreciated...
Anders..
Post Tue Jan 03, 2006 10:43 am
Is it the key that wont lock the car, or the pin?
AndersLS
Post Tue Jan 03, 2006 11:42 am
Danthe...I think its the pin. The key goes in,...and rotates...but nothing happens.
Post Tue Jan 03, 2006 11:49 am
I mean the door pin that you press to lock the car from the inside,
does the key not lock the drivers door either?
AndersLS
Post Tue Jan 03, 2006 11:54 am
Danthe...when I try to lock the drivers door from the outside...the key goes in and turns, but the door(s) doesnԚ´t lock. When I lock the door from the inside(pressing the pin) it locks everything just fine.
So the only way I can lock the car from the outside is via the boot lock.
Post Tue Jan 03, 2006 12:00 pm
Sounds like you have some problems with the lock barrel itself, ie. not turning onto the microswitch or flicking the lock lever. The deadlock parts do tend to wear out a lot
What about the other door?
ian332isport
Post Tue Jan 03, 2006 12:20 pm
Hi Anders,
It's not uncommon for the mechanism on the inner end of the lock barrel to break or fail in such a way that the barrel turns, but the linkage on the end does not.
Have a read through some of the lock articles here for more info.
http://www.bmwe30.net/cgi-bin/datacgi/d ... Section=01
Cheers,
Ian.
Templ8e30
Post Tue Jan 03, 2006 3:06 pm
You can buy a lock repair kit from the BMW dealer for about Ԛ£18, it comes with all the lock parts and a bag of coding pins so you can code it to use your existing keys.
Part number is REPAIR KIT LOCK CYLINDER RIGHT 51219061344. I think :mad:
Cheers,
Iain T
2007 Mazda 6 2.0 estate
Post Tue Jan 03, 2006 5:14 pm
Great info Iain :thumb:
No more messing about with 20 year old barrels for me :D
AndersLS
Post Tue Jan 03, 2006 7:10 pm
Ian...just perfect! :D
Andy335Touring
Post Tue Jan 03, 2006 8:38 pm
I did this over christmas, not a hard job when you follow the guide that Ian posted and take a few pictures of it your self before you start to take it apart, this is what you get in the kit.
