electric door motor & locks
Aziz
Mon May 06, 2013 12:07 am
Hi
Im upgrading the electric motors and glass in my chromie
Just wanted to check Ive done it right
some pics
Also passenger side lock does not lock/unlock door or central locking
If internal locking pin is up central locking from drivers side or boot locks then unlocks instantly.
If I push pin down on passenger door central locking works
Im posting pic can someone tell me whats missing and were a cut wire goes
Aziz
Tue May 07, 2013 7:54 pm
Motor and glass fitted
Only thing is that when window is lower it fall forward a little.
When going back up fall back into runner.
I believe addition securing/adjustment hole needs to be drilled.
Can someone give details of were that should be done
ranxerox
Wed May 08, 2013 8:24 pm
delete
Aziz
Thu May 09, 2013 9:30 pm
ranxerox wrote:A couple things. There may be a rubber type strip in the bottom channel that is missing, old dried and cracked, or the glass needs to be seated down fully into the bottom channel. Tilting can be caused by misaligned side rails, wornout lining on the side rails(I'm not sure what it's called but it's fuzzy when new)or the siderails/gudes may be pinched bent or some such. There could be other causes but I would check these first especially the bottom cannel the glass rests in.
The side channels should be held by a screw at the bottom yours could be rusted out, missing, loose, etc.. be sure to check those.
As far aas I can tell window is sits fine, side rails are good both weather strips inner/outer are ok.
When the previous chromie S type electric window mech was in window went up/down fine.
I think its something to do with vertical adjustment two nuts on left side of pic 1.??
thanks
