hi guys,
my rear drive shafts just keep breaking !?! is there any other solution other than the z3M route?? what are you other turbo guys running on your cars??
breaking driveshafts on turbo e30
ranxerox
delete
I think your getting mixed up with something else, even 316 driveshafts are the same as whats on a 325iranxerox wrote:You said an e30. The 325e had a different shaft than the 325i due to the increased forces. You may only need to go to an I shaft. Also how much boost are you getting from your turbo, depending on that will also determine how much you need to upgrade.
There is a guy on here with custom driveshafts, they have UJ joints rather than CV joints
ranxerox
delete
Im guessing your american and are confusing driveshafts with propshafts
ranxerox
delete
kam-325i
They appear to be different according to the Parts listing....
