318is No Heat !!
smudge
Just experianced no heat from heater..car getting up to normal temp but there is only a very small heat even when on full blast ..Idea's ??? Thanks
You either have low coolant, a failing head gasket, or the heater pipes are connected the wrong way around if the matrix is cold.
The E30 heater is an air blending type, so there's a small possibility that the linkage to the flap in the heater box has come adrift somehow.
smudge
Just checked this morning..Your were right Brian...low coolant..topped it up with red coolant & presto...loads of heat..cheers..simple things eh !!!
Not quite that simple, I'm afraid. Next thing to find out is where the coolant went, and whether what you've added is following it!
smudge
Found the leak.. Coming from the heater & passenger footwell wet !! Heater matrix ??
Electric valve is much more likely.
smudge
Can those electric valves be purchased anywhere ?
You'd struggle to find one in your local Tesco's, and I don't think the likes of GSF or ECP do them either.smudge wrote:Can those electric valves be purchased anywhere ?
BMW will have plenty, and there's no shortage of second hand ones around.
First thing to do is take the covers off and see exactly what the problem is. Could just be the O ring seal between the valve and the matrix.
