Stripping the underside of the chassis.
Craggy73
Post Mon May 06, 2013 1:53 pm
Well, I've started the laborious task of stripping the underside of my car. I'm using my grinder with the flapdiscs and twisted wire wheel, which seems to do a decent job. Just wondered if anyone has any tips and tricks for getting into the tight spots where the grinder can't reach? I have a small Dremel drill but it's more suited to craft and hobby work. I'll buy a bigger version or some other tool if needs be. Any recommendations?
ross_jsy
Post Mon May 06, 2013 2:20 pm
You trying to take the under seal off? Nitromoors it and leave it to soak in then scrape it off
Craggy73
Post Mon May 06, 2013 5:28 pm
I am. Will give that a go, thanks.
Grrrmachine
E30 Zone Wiki / Team Member
Post Mon May 06, 2013 5:45 pm
Heat gun and a paint scraper. You'll go through a dozen wire wheels on a grinder, and flapdiscs will thin the metal if they're fresh.
Craggy73
Post Mon May 06, 2013 8:24 pm
I did buy a blowtorch thinking about burning the sealer off but maybe that's a bit agressive. I've ordered some Nitromors so will see how I get on with that. Think my neighbours will appreciate the quieter approach :D
maxfield
Post Mon May 06, 2013 8:25 pm
I use a blow torch and a scraper generally. Just have to be careful
Post Mon May 06, 2013 10:11 pm
i used a drill with the appropriate tool fitted to get into the nooks and cranny's
http://www.ebay.co.uk/itm/3pce-ROTARY-W ... 19c3ee1886
http://www.ebay.co.uk/itm/2-Piece-Rotar ... 589f39fc2d
happy rake out
Craggy73
Post Tue May 07, 2013 11:53 am
Magpie, I've got some wire brush attachments for my drill, but even using them on a mains drill doesn't seem to be tough enough compared to a grinder. Hopefully the chemical method will make life easier.
