I found out today that the carpet was a little wet. Have read in e30wiki that it is something from the heating system.
How much should I strip down to get in and see what's wrong? Can I do this / is it easy enough?
hope anybody can help
okay thanks. I have removed the glovebox.Jim320i wrote:If you dont take it out in the rain then ignore the above apart from capri_rob, it will be heater related.
okay thanks alot... My BMW is LHD. so I should not remove the glove-box??Grrrmachine wrote:Brinkland, just remember that when these UK guys talk about removing the glovebox, it means removing the panel under the steering column on left-hand drive (LHD) cars like we have in Europe.
Thanks!Jim320i wrote:You need to remove your Driver side under dash trim.
The things behind the dash are all in the same place as RHD, its just the exteria thats different.
To remove the under dash trim its just 3 plastic scres at the front and one in the centre, watch the back section as this clips into a clip onto the steering column so you want to pull it forward, if you visually look, you'll spot it, then its in the same place pictured above, you'll spot it straight the way
the black thing is a clutch mastercylinder? Its comming from it. if I press many times on the clutch pedal, it will be wet by the rubber piece.Jim320i wrote:You sure it's not clutch fluid if its coming from the clutch pedal? It could be your clutch master leaking. Check the fluid bottle in the engine bay for a start to see if its empty if if the brake one is low?
