Welded wheels
guss
Can alloy wheels be refurbed back into original condition once they have been welded.recentley I picked up some alpinas and was told the front wheel had been welded,it's a set of 5 so I thought I would use the spare anyway and could may be find a single one in the future .
andyp
- True Old Skooler
yes wheel refurb companies do weld alloy wheels and i would say as a spare it will be fine
guss
Thanks,just wondering if you could get it back to mint condition or would it be impossible to get perfectly round as the welded section seems to dip a little so not perfectly round.
andyp
- True Old Skooler
o so it was not done by a proper company then , maybe i in that case i would not want to use it
zaust
- Zone day release
guss
So if welded properly it's as good as new.
kam-325i
If its welded properly, you should not to be able to see the repair......
Genuine Alpina wheels? The 17 inch reps are well known to split when they get flat spots
reggid
welding and aluminium aren't a good mix as you lose what little hardness and strength you had by essentially annealing it and the likelihood of cracking goes up if they do a poor job. despite all that it is very common and never heard of a problem. the wheels they just aren't stressed much unless you have very low profile tires and start smashing into pot holes. i wouldn't worry at all
E30 325is with M20B31
split rims...a brand new world .
+ a yard full of scrap turds
guss
So it's likely being genuine alpina staggerd 20 odd years old that you'd find it hard to come across a set without ever being repaird.thanks for the replys
