Head lamp restoration kit pre face lamps
polsta
Post Sat May 04, 2013 1:19 pm
Anyone used a head lamp restoration kit ? Like the £19.99 meguiars one ?
Just wonderd what is in the kit if its worth buying and has proper stuff and a few bits or if its just a few standard items you can buy cheaper ?
Lamps are a bit milky and weathered and want to get them like new
And also - is it possible to remove the glass from pre face lamps to get at and clean the insides and silver reflective bit ? I had a little go but they didn't look like they wanted to budge
ajay
Post Sat May 04, 2013 3:16 pm
The glass lens will come off with heat applied all round but its a risky job. If you fail you can get replacement lamp inserts.
polsta
Post Sat May 04, 2013 3:45 pm
Probably expensive tho ? How much heat ? Heat gun heat ? I've got some spares, also have some facelift spares , is the actual glass/fit the same although the rest of the lights are different ?
Was re painting one and the lenses actually fell out of one and had some slight surface rust around the join area, and the reflector was very grubby and cleaned up great, what would best be used to re glue them ?
bab-91
Post Sat May 04, 2013 4:04 pm
Buy new headlights you cheap git :D
IG - bab91
polsta
Post Sat May 04, 2013 4:21 pm
Tight lol !! New ones are probably absurd price
bab-91
Post Sat May 04, 2013 4:28 pm
TWIN HEADLIGHT LEFT 63121370697 $254.45
TWIN HEADLIGHT RIGHT 63121370698 $254.45
I have them on my parts list. Throw them at bmw for a price 8)
IG - bab91
polsta
Post Sat May 04, 2013 4:46 pm
Fk that one day maybe I'm not paying out probable £450 odd
I've had the metal casings blasted and powder coated , rubbed down and re painted the backs of the lamps , just got to do the glass and fittings and they be good as new hopefully
bab-91
Post Sat May 04, 2013 4:48 pm
You could buy a new shiny set and use them for shows only.
Avoid the inevitable road rash :mad:
IG - bab91
PG325
Post Sat May 04, 2013 5:44 pm
Isn't the Meguiars kit just for plastics lenses? I'd check what kit you're looking at because I've only seen them with Plast-rx paste, not sure if that will touch glass.
I've used Cerium Oxide paste before on a rotary pad to the outside face of a smiley and that worked a treat. You can buy the powder cheaply enough and mix with water.
polsta
Post Sat May 04, 2013 5:56 pm
Nice one thanks mate , sort of info I was after , didn't know it was for plastic
Been googling it, all sorts of methods from toothpaste to wet sanding and even says you can wax them after wtf lol
Post Sat May 04, 2013 6:16 pm
ebay.de have new lights for not alot of money, just require the mod to turn them to rhd. Easy
polsta
Post Sat May 04, 2013 6:27 pm
How much ? Got a link are they genuine ? Pre face ?
ajay
Post Sat May 04, 2013 10:50 pm
Alex wrote:ebay.de have new lights for not alot of money, just require the mod to turn them to rhd. Easy
I did not think pre facelift lights could be converted from LHD to RHD, i know its a simple task for facelift jobbies.
