So it begins ! Rust Never Sleeps! Drift/Track
Nato_e30
Nice one I remember tackling my sunroof cassette managed to get it out and was such a relief when it dropped and t*ated me on the head!
Nato_e30
mattrs
Halfords is your friend... They do an assorted pack.BATTS91 wrote: as soon as i find my knotted wire wheel ill be onit !
BATTS91
Found mine .
After advice ect . I have come up with this solution .
BATTS91
Finished up these brackets for the sunroof today , unsure if im happy tbh quite abit of faffing to get the panel level . Will have to make spacers and adapt how it will bolt down .
Its level but bolting it to the brackets is going to be agg , alot of thought needed tomorrow
jimbom30cab
- Tech 1 freak
top job mate, can you quote me to do my car please
this could be a whole new career for you!!
BATTS91
I wouldnt go that far lol .
And errr be slightly difficult as you own a cabbie dont you ? Lol
jimbom30cab
- Tech 1 freak
oh yer, sorry got a bit carried away there with some zone lovin !!
BATTS91
Haha , thanks tho , took a while to make brackets , time will tell tho .
BATTS91
Change of plans with the sunroof . Dont like the brakets at all .
Soo today i received this handy little tool that helped me out alot today .
All sound deadening inside the "cockpit" may you call it is removed .
Then rethinking on the whole sunroof idea , had a look and i worked out how to seperate the two skins on the sunroof panel .
I used the grinder on one spot weld and thought id try hitting the scraper , after about 30-45 mins of carefull faffing about with said scraper and a rubber mallet .
I ended up with this .
And this , which i beleive is also older than me , i dont think my grandad will be best pleased if i continue to break and bend his tools lol (i do replace the broken tools)
Anywho , what i shall be getting is some 4mm stainless wire rope to go all around the panel and tack weld onto the panel, from now on its trial and error . I hope i will be satisfied
Thats all for today folks .
BATTS91
Rust never sleeps!
BATTS91
Soooo ive been getting a little down and dirty lately cutting out rust and removing shizzle , take a look.
Spare wheel well ,Grinded back the seem sealer and drilled out the spot welds . The only part that seems at all weak is the n/s/r corner of the hole
Then onto the rear valance , im working on all the rust on the drivers side for the mo so i dont have to turn the car around due to space .
cut out the rear valance and part of the rear box or whatever technical term for it is . Rust !
Then this ... Ground it down and a coat of Hammerite rust cure stuff .
Moving on to inside the car !!
quite luckily the points for the throttle peddle seem solid !!
Front drivers jacking point !
before i drilled the spots out for jacking plate .
for now its all shot with some primer until my welder is working or unless i can borrow one for a weekend !
BATTS91
I also weighed the sunroof tray and inner skin of sunroof panel , the result was 10kg , so quite abit from the roof !!
also if anyone can suggest tool other than a vice for bending sheet metal thats an average cheap price would be appreciated , i will be getting a joggler tho
also my plans were to go m52 but considering keeping the m50 and saving more to do a turbo conversion on standard management maybe running low boost with holset hx35 or equivalent with a goal of 280- 300 hp .
Andeep
Clamp the sheet you want to bend between 2 pieces of right angle steel and tap it over, then planish it. Or buy/make a sheet metal folder
Don't bother using a joggler to make lap welds, do it properly and butt weld in it. Just practise a lot first.
I highly recommend this DVD if you are starting to learn metal fab:
http://www.metalshapingzone.com/
McGoo
when im messing with sheet metal i got hold of a girder and use it as an anvil. works well with a hammer and abit of heat. good progress so far
rob0r
Impressive work with the sunroof and wheel well, two jobs that seem awful but you made look easy. An interesting project!
jimbom30cab
- Tech 1 freak
Hi Rob, not heard from you for a while, how's the new M30 project going ?
