replacing brake lines
Bally
Post Wed Apr 24, 2013 8:57 pm
Hi MOT time last time had advisory on rusty brake lines so assuming will fail on this. how easy is it to replace them .also
should I go for copper pipe and flaring tool , or get steel pipes from BMW (understand they are cut to length will the fitting already on), which pipe is better steel or copper is this a diy or a pita to do . thanks
tom325sport
Post Wed Apr 24, 2013 9:29 pm
I did this myself - just take your time.
http://www.e30zone.net/modules.php?name ... t=#2320205
Motorhole
Post Wed Apr 24, 2013 10:29 pm
If you do your own, don't use copper as it hardens and becomes brittle with vibration. Kunifer is the material to use, copper-nickel alloy. Most motor factors/online shops/ebay stock it :)
tom325sport
Post Wed Apr 24, 2013 10:34 pm
Motorhole wrote:If you do your own, don't use copper as it hardens and becomes brittle with vibration. Kunifer is the material to use, copper-nickel alloy. Most motor factors/online shops/ebay stock it :)
This.
