Outside Temp Sender connector .. broken :(
pebisit
Post Tue Apr 23, 2013 8:33 am
The blue and brown wires that feed into the connector on teh brake duct of my outside temp sender have broken at the actual connector. Does anyone know if you buy the connectors with some cable attached so I can re join htem back into the main loom??
Or can you buy the connectors to join onto bare wire as they look pre formed to me
Grrrmachine
E30 Zone Wiki / Team Member
Post Tue Apr 23, 2013 3:39 pm
Go to any scrap yard and cut some off any other BMW - it's the same connector as the headlights in the engine bay, as well as most of the other engine sensors (coolant, washer pump and level sensor etc). I nabbed a load off an E36 for 50p a plug.
