What type of connection is there from the OBC to the sensor on the factory setup? I have the OBC loom which puts a few connectors over by the glovebox. I also have a two pin loom which plugs into this and goes through the bulkhead (terminating in 2 wire ends for me).
Hadn't installed my OBC before because the donor car had front end damage and was missing the temperature sensor. Noticed a scrap E34 with OBC today. Measured its probe resistance and saw it was good for the E30 too (later found out they are a shared part for from 89 on).
From the E34 end I have a headlamp type connector which plugs into the sensor which snaps into the E30 brake air duct.
The ETK seems to show a brake wear sensor type connector between the bulkhead and the probe. Is this for the pre-89 setup only? I don't see a need for a 3rd short loom!
BTW, I'm fine electrically here, just wanted to use as many factory type looms as possible.
OBC outside temp sensor question
Davenotouring
Dunno if this helps.....
I know you are sh1t hot with electrics but.....
The OBC loom has a clear translucent connector with two pins, this runs down to the brake duct where there is a yellow connector (same connector as the headlight ones as you said) which plugs into the temp sensor.
Did you already know that or has that helped?!?!
BMW 328i Cab - Daily Slag
Davenotouring
No probs mate.
Glad to help.
Glad to help.
- Brianmoooore
Diagrams on the ETK are for identifying part numbers only. In quite a few cases the actual parts look nothing like those shown on the ETK.
- SeamanStaines
The later E34/E32 sensor is the same as the E30 and the E36 too (part no on the sensor is 1383 204). I've found that the later type sensor can be a tight fit in the air duct hole though and need a good shove.
As for the wires, look on the sensor and it has a flat side and a curved side. The flat side takes the brown/grey wire, the curved side is the blue/red (often with yellow dots).
Now, use a nailbrush and scrub the yellow plug connector clean. Look on the end where the two black connectors go into the yellow connector block and you'll see the numbers 1 and 2. Number 1 (curved side of the sensor) is the live which on an E30 will be blue with a different colour tracer - on an E34 or E32 it's blue with a red tracer. Number 2 (flat side of the sensor) is the earth which is brown. The E32/E34 is brown with a grey tracer.
On the E36, brown orange is earth and brown/grey is live.
