Need mud flap help - cant find the BMW U-shaped clips?
clydesdale
I need the u shaped clips, bavarian auto doesnt have them, they act like no one makes them. Bmw dealer is not familiar with them. They came in the mud flap kit from bavarian auto. I explained that the picture on their website is not what is on my car. I need the U-shaped clips to hold the rear mud flap to the plastic lining of the wheel well. Please help. Thanks
Theo
I've just removed my rear mudflaps and have got clips of some sort lying about, can you show me a picture of what it is you are after by any chance?
Steviec
Fiat Stilo mud flaps use U shaped clips with allen key bolts going through them. These are a current part and may be able to do the job.
clydesdale
theo325, Thank you!! To see a pic, the best way is go to www.bavauto.com. Search for parts for an 87 325is, type mud flaps into the search and you will see u clips for the FRONT. I need them for the Rear, not the clip that bavauto shows. I need a U-clip, just like the front, only they are about 33% longer. Thanks
E30Mark
Are these flaps genuine BMW parts? if so i believe the clips are 72.60.8103.010 about Ԛ£1 each.
PM for details
PM for details
Bob_S
Ԛ£1 each??? your getting ripped off!!! I paid 23p each for some back in the summer
Bollocks to this 24v scrap!
E30Mark
I was guessing !Bob_S wrote:Ԛ£1 each??? your getting ripped off!!! I paid 23p each for some back in the summer
clydesdale the parts you need are on the bavarian auto website...
PM for details
PM for details
clydesdale
they are not on their site. If you look at bavauto they have the u-clips, but for the front only. The rear clips they have are not u-clips, but some sort of clamp. I need rear u-clips. Front ones will not work on the rear, they are too short. THanks
clydesdale
e30mark and BobS, I looked up that part number and that is for a clamp type of clip with a screw. Mine are simply u-clips in the rear. Is there another way to clamp these? Can you describe how these clips work, mine clamp on the same way as the fronts, with the u-clip. Please help. Thanks
E30Mark
My car has the clamps! I'll try and get a photo up asap
PM for details
PM for details
clydesdale
thanks, I look forward to the pictures. I hope they will shed some light on this. Thanks
E30Mark
At long last a photo! Sorry i didn't get to clean my car first...
Use thie clamps mentioned on the bavarian web site
Part Number 72 60 8 103 010 Mud Flap Clip - Rear $2.95
You need 4 off.
You need 4 off.
PM for details
PM for details
clydesdale
Thanks!! How do they actually connect? Does it just catch the inside of the fender well and just clamp? I would assume the side with the teeth just sets into the rubber part of the flap and the other side goes into the fender well. The bolt does not attach to the car, correct? No drilling, correct? Thanks again for taking the time for a pic.
E30Mark
Your assumptions are correct, the teeth dig into the mud flap, the other side clamps on the edge of the arch (fender). No drilling required.clydesdale wrote:Thanks!! How do they actually connect? Does it just catch the inside of the fender well and just clamp? I would assume the side with the teeth just sets into the rubber part of the flap and the other side goes into the fender well. The bolt does not attach to the car, correct? No drilling, correct? Thanks again for taking the time for a pic.
PM for details
PM for details
