Diff casing sizes explain please
manse73
Post Sun Apr 14, 2013 9:32 am
How do you tell what size diff is what
I have an 1.8 diff and want to fit a 2.5 diff
What would I need to also change
The car is running a 2.5 engine and manual gearbox
Sebring grey motorsport convertible
Post Sun Apr 14, 2013 9:43 am
Easiest way to tell is to count the bolts that hold the rear cover in place. Six on a small case and eight on a medium case.
Nothing has to be changed to change from one to the other. The narrower width of the small case is made up to the width of the medium case by spacers built into the output drive flanges.
Grrrmachine
E30 Zone Wiki / Team Member
Post Sun Apr 14, 2013 10:49 am
**BANNED**
Post Sun Apr 14, 2013 11:31 am
Brianmoooore wrote:Easiest way to tell is to count the bolts that hold the rear cover in place. Six on a small case and eight on a medium case.
Almost correct!
The propshaft length needs altering slightly at it's centre join,slacken the collar nut and slide the rear half forward about 13mm,re-tighten the collar nut.
Reverse the above if swapping from a medium case diff to a small case diff...
manse73
Post Sun Apr 14, 2013 12:43 pm
Thank you both. What would be the best ratio to use so it is not revving its nuts off on motorway usage
**BANNED**
Post Sun Apr 14, 2013 12:57 pm
4:1 gives 65mph at 3000rpm
3:64 gves 73mph at 3000rpm
Above assumes manual 'box.
So 3:73 and 3:91 will fall between the above quotes.
Youth is wasted on the young.
Post Sun Apr 14, 2013 2:19 pm
Almost correct!
Propshaft sleeve should be slackened off at EVERY diff. change, regardless of whether a change of type is involved.
manse73
Post Mon Apr 15, 2013 4:38 pm
Will I need to change the speedo or sender
**BANNED**
Post Mon Apr 15, 2013 4:56 pm
manse73 wrote:Will I need to change the speedo or sender
No.
The speedo's are all the same,although I think the M3 may differ,and the sensor reads from the output side of the diff and is the same for all E30's.
manse73
Post Mon Apr 15, 2013 11:40 pm
Again thanks for your help I am now looking for a 3.64 open diff
manse73
Post Wed Apr 17, 2013 8:06 pm
Will a diff from an e36 fit and if so what would be the best ratio to look for
capnmchl
Post Wed Apr 17, 2013 11:04 pm
Nope. Different mounting design.
However, I'm led to believe E36 internals can fit inside a medium case diff, although it seems a lot of hassle.
