air lock
ezlife53
Post Sat Apr 13, 2013 5:19 pm
hi any 1 no how to get an air lock out of a 325 i :cry:
ross_jsy
Post Sat Apr 13, 2013 7:45 pm
Have you tried bleeding it with the front elevated, either on a steep hill or jacked up?
aimlessrock
Post Sat Apr 13, 2013 8:12 pm
as per ross's remarks, but if they fails to rid the air locks get it to a garage and have it vacuum bleed....it take minutes and it should only cost you a pint.
E30 320i Convertible (1989)
190 Mercedes (1988)
G-Bear
Post Sun Apr 14, 2013 3:24 pm
I had this problem a week back or so.. Read Andyboys comment near the end. That and raising the front to bleed it at the thermostat as already mentioned worked a treat. Also get the revs up to about 2.5K
http://www.e30zone.net/modules.php?name ... c&t=236041
