bab-91
I sprayed the parcel shelf. Autogylm fabric dye isn't worth a fiddlers f.u.c.k
IG - bab91
IG - bab91
milescook
"Made" a new door card, (the mirror switch wiring rubs on the window as it winds
), replaced some dodgy bulbs, "made" a new windscreen wash solution, replaced a windscreen wiper, gave it a clean and a hoover inside, fitted a new battery bracket, bled one brake, glued things like the check panel in place, bolted down the ecu, tidied up some cabling. Admired my "handywork" ....
Wednesday it's headed out (1st time in over a year) for an MOT.... hopefully.
Also please help the race budget by watching some videos
https://www.youtube.com/cookracinguk
Chris_B86
Fitted new rear back plates, bearings, poly bushed trailing arms, new H&R ARB, H&R suspension, new top mounts, new drop links...
FinalD
Refitted the arch liners and front under tray/splash guard then took it for a short blast, so much exhaust noise, it's soooo much fun!
I need to investigate why occasionally it won't pull away without 2k+ rev blip, doesn't always do it.
1988 325i Cabriolet - Gone.
Darren325is
Set tappets. Didn't make a shite of difference
RobbieT
Bolted the new front bumper back together and onto the car, realised the valance is very much bent and needs a new one. Went to swap broken headlight for one of the spares, has wrong bulb holders so needs different type. Started to look better and worse all at once today, maybe i'll start a journal ...
Got an Advisory-free MOT pass first time
jmc330i
Got those on my Sport. Great winter wheel as they are so easy to cleanbab-91 wrote: Tried the style 15's on as i've had them sitting... meh!!
Also, no f*cker wants to nick the centre caps, unlike the BBS caps!
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
Topblag
Removed the exhaust, rear heat shield, and log manifold on my cabby, checked the spark plugs, drained the oil and test fitted the magnex 6 branch which is going on, with a matching stainless zaust.
No broken studs
No broken studs
1984 Hartge H35 in Black
2006 Audi S6 V10 in Black 58k
shedrool83
jimbom30cab
- Tech 1 freak
Gave it a good clean and a damn good polish after 7 weeks of cutting/grinding/welding and painting blar blar blar, which only resulted in one trip to A+E. LOL, metal filing stuck in my eye ball which was scraped away with a sharp needle after it was injected with an anaesthetic.
sunnysr
took the rocker cover off the engine that wouldnt start ....
9 of 12 rocker arms snapped all on the inlet side ,cam belt looked ok ,heads coming off later ,bought it as a spare engine to drop in while i removed mine to turbo build that ,but it wouldnt start when i put it in so took it back out now deciding if i should just bust it for bits and go 24v or rebuild it
Blimey, what would have caused 9 rockers to snap all at once?!
sunnysr
thats what i want to know ,all the inlet side have snapped and 3 on the outlet side ,cam belt looked good and not that old but maybe it jumped a tooth or something
taylorstattoo
nice looking car,, remember,, always use safty squint,,, loljimbom30cab wrote:Gave it a good clean and a damn good polish after 7 weeks of cutting/grinding/welding and painting blar blar blar, which only resulted in one trip to A+E. LOL, metal filing stuck in my eye ball which was scraped away with a sharp needle after it was injected with an anaesthetic.
RobbieT
That is looking lovely for a clean, worth the pain i betjimbom30cab wrote:Gave it a good clean and a damn good polish after 7 weeks of cutting/grinding/welding and painting blar blar blar, which only resulted in one trip to A+E. LOL, metal filing stuck in my eye ball which was scraped away with a sharp needle after it was injected with an anaesthetic.
Rtaylor2208
Rebuilt the front struts replacing the top mounts, spring pads and washers (dampers and springs done 600 miles ago). ARB drop links and bushes also done.
Power steering pipes replaced as they were leaking, rocker cover and inlet manfold cleaned and sanded in prep for paint.
New fuel pipes in the engine bay plumbed in.
Injectors removed to send away for a refurb. Lots of little BMW bags arrived today with all the new nuts, washers, gaskets, O rings and a few vacum pipes so I can get the inlet side all put back together.
Altogether good progress since it was sunny up here today.
Lots more arriving tomorrow from CP4L and another order going into BMW for bits I forgot.
BHadley
Fitted my DIY refurbed 15" BBS , came up nice too.
Visited a scrapyard in Woodbury as tipped by here to get a few parts
A non rotton door in the same colour is a fairly good find!
2x 320 e30 at that yard, one 2 door in red, one 4 door in grey. for those in need and in devon its Woodbury car breakers......
Morat
Overtook an RS-6 on the way to work
ok, he had a dog wandering around the boot so he let me past...
gary
Rubbed down my alloys in reediness for a refurb
boomerm20
Added extra tail and brake lights.US cabrios came with an unsightly boot mounted brake light,which I replaced with a bootlid from a coupe.
The bulbs are also brighter than standard bulbs.
tomislav
Cleaned it last night and then drove it to work today to go to Prept at Brands Hatch tonight.
This bank holiday weekend its in the garage for complete running gear replacement
darkchild
Washed and polished with autoglym products before a healthy coating of their excellent HD wax. Refitted the summer wheels, 15"BBS coated in Vredestein Sportrac 3s. Drove it 60 miles to Cambridge and the aging Vredesteins are so much more noisier than the Goodyear Ultragrip 8 Winters that were fitted. This will probably be their last 6 months on the car before I replace them. Sadly one of my winter tyres has a puncture so will also need replacement but at least new ones are cheap on eBay at this time of year.
Next week? I need to get some 3M underseal ordered for a couple of very minor touch up jobs and then the plan is to just enjoy driving it.
jimbom30cab
- Tech 1 freak
looks lovely, white and chrome FTW
Quaser
ive been a busy boy -
finished fitting lsd
worked on getting rid of some of the fault codes - mostly sorted
found the front arch piece that id lost and fitted that
fitted a nice shiney storm motorwerks gearknob
fitted my eonon screen/tv - was nicely suprised that it didnt interfere with the indicator stalk
fitted my armrest and centre console
discovered that the seat mechanisms are knackered so seat has to come back out and sorted
tomislav
Bought an OS outer sill, rear panel and more welding wire!!!
G-Bear
Changed;
Timing belt, tensioner pulley and spring (there was no spring in before
Water pump
Cam seal
D bungs in head
Coolant
Oil
Oil, fuel and air filter
Spark plugs.
and replaced cable ties with a few satisfying clips and housings that BMW intended to keep wires tidy around the front of the engine.
Did that last week.
Yesterday swapped my faded grey grilles around the lights with nice black ones.
Today adjusted the valves for the first time... and have made them worse
Water pump
Cam seal
D bungs in head
Coolant
Oil
Spark plugs.
Did that last week.
Rtaylor2208
Just about to go and make a start on changing the prop centre bearing and the rubber donut. Expect que
stions in tech help later
adam_2922
I fitted a new steering wheel, changed the air filter, changed the centre console, put in new gear and handbrake gaitors and replaced the bonnet and boot badges. Kept me busy!
kangman
washed it... and now its p1ssing it down
MY FACEBOOK PAGE- CLASSIC STANCE
http://www.facebook.com/pages/Classic-S ... 6444884427
MY FOUR EYED BEAST
MY FOUR EYED BEAST
taylorstattoo
fitting new windscreen today ready for mot time, refit bonnet, bleed brakes and sort out the interior ,, hope my new exhaust iv made passes mot emissions..
Andyboy is up the passage and there is a bit of quattroporte love planned ! Pics to follow !
manse73
Put mine in its garage to keep it dry for the summer
Sebring grey motorsport convertible
