My car is sitting on BOGE Turbo shocks, but i am needing to stiffen the springs. the ride height is perfect for me, just need stiffened.
So what are my options to stiffen it up a bit?
Cheers in advance.
George
Stiffer Springs??
Rtaylor2208
Do you know what springs you have already? I.e. Standard, MTECH or something else.
Topblag
THis was Graham's car. Probably 40mm drop if you haven't changed them.try the mech II ones, best of both worlds and properly engineered for the car.
1984 Hartge H35 in Black
2006 Audi S6 V10 in Black 58k
gmf_uk
Aye its grahams old car, the drop is good, think its 60mm front 40mm back. i just need it stiffer, as the front tyres catch the arches sometimes,
G-Bear
I had that with an old E30.. need to nip it in the bud fast. Your tyres will unfold the lip on your arches before long, remove paint and start to corrode.gmf_uk wrote:Aye its grahams old car, the drop is good, think its 60mm front 40mm back. i just need it stiffer, as the front tyres catch the arches sometimes,
For after market springs Eibach or H&R are a popular choice. Some say that H&R are a bit stiffer.. so perhaps worth doing a little research into them..
