best stuff to use for rustproofing on sills etc
matt86
Post Wed Apr 10, 2013 5:52 pm
What's the best stuff to use to rustproof a car, i used kurust on any surface rust patches which were very minimal, then sprayed waxoyl on from halfords, which also has a rust prevention/eater agent in. Would terraseal be better?
i still have one sill to do and was thinking of doing where the arches sit under the mtech kit, for rust prevention in the future.
any recommendations on cleaning underbody of car and rust proofing etc?
cheer
Rtaylor2208
Post Wed Apr 10, 2013 5:56 pm
If there is any signs of rust on the cills, clean them back to bare metal , then paint with stonechip paint. That waxoil stuff with the rust killer in it wont get rid of the rust and it will come back underneath.
matt86
Post Wed Apr 10, 2013 6:01 pm
Rtaylor2208 wrote:If there is any signs of rust on the cills, clean them back to bare metal , then paint with stonechip paint. That waxoil stuff with the rust killer in it wont get rid of the rust and it will come back underneath.
cheers mate. Will do that. Thanks for the advice
polsta
Post Wed Apr 10, 2013 7:28 pm
you ask a few times about this sort of thing, it sounds like you need to do a proper job- car on stands/ramp, wheels and arch liners etc removed and strip it all back, sort rust properly, re seal it all properly, if you do little spots here and there and mess about- your forever chasing it, and if you just touch up a bit thats got deeper lurking and waxoyl the top as abovbe- it will fester away
also- did you paint it ? kurust isnt great, the magical fertan :) is much better, and get some touch up paint from paints4u (£12 odd) which somes perfect color match, and when you do any little bits, you paint it after if its just touch ups, then also if its a visible area, you can then blend with a g3 type product after
youd do better to post pics and close ups of the areas you are on about
