What i want to know is what order you would put it all back together in? ie bolt ARB up then struts, or would you get the lower arms built up first and bolted on then get the struts on etc..
Thanks (in advance)
Ill be tackling this tomorrow on the drive in the freezing wind so id like it to go as smooth as possible.
