Hi everyone. I just uncovered and took my 1990 325i convertible out for the first time since santapod last year and noticed the temp needle when I turned the key on rockets off the scale!!!!
Engine is cold so what could be the cause? Sender unit, gauge? I don't know as I've never had this happen before...
Any ideas welcome
Temp needle ott
Rtaylor2208
I would check the wiring first of all as it wont cost anything.
I had a very tempremental guage that would bounce all over the place. In the end it turned out to be the instrument cluster after stripping and checking all wiring and replacing the brown sensor.
Unplug the C101 engine loom plug by the fusebox as a first test.
Does this make the gauge stay at cold?
trevski
Ok I will go and do that now. I have already pulled the feed for the brown sensor and it stayed down.
Will report back
Will report back
trevski
Ok I disconnected the c101 loom plug and indeed it did not move .Brianmoooore wrote:Unplug the C101 engine loom plug by the fusebox as a first test.
In that case, the sensor is faulty, or just possibly the wire to it was shorted to earth nearby, and unplugging it disturbed the short.trevski wrote:Ok I will go and do that now. I have already pulled the feed for the brown sensor and it stayed down.
Will report back
trevski
I am collecting a new sensor in the morning and I will post my results when fitted. Thanks so far
trevski
All fixed after the sensor was fitted
thank for all your help
