E30 318is Coupe With Factory LSD
- Tabbi
Hi guys, i have just bought my first E30 after owning several E36/E46's and it has not been a good start.
After having a bit too much fun in the snow, the car no longer likes to go round corners smoothly. There is a jolting coming from the rear and a grinding type noise can be heard from within the cabin. It drives fine in a straight line.
I know the car is fitted with the factory option 4.1 LSD and im hoping it is not Kaput! Please...please...please....
I am new to this forum and your advice will be very much appreciated in regards to what it could be and what my options are.
Regards
Tabbi
Regards
Tabbi
Rtaylor2208
Do you know the last time the diff oil was replaced or checked?
- Tabbi
Hi, TBH it looks like most of the oil is outside the diff rather than inside it! Ive only had it a couple of days and was going to get everything done but i just couldnt resist throwing it around in the snow! The previous owner had deep pockets and short arms so i dont think he had replaced anything. Luckily he didnt have it long as the previous lady owner prior to him had spent a fortune on it and maintained it regardless of cost.
- Tabbi
No dont be sorry, you have been really helpful and i appreciate your time. I have sent him a message and will keep you posted once we have spoken. Ive just seen that he is all the way in Sussex and i am in West Yorkshire....this might be tricky.
Is there any other LSD that will fit in the meantime without having to buy a load of other bits just to make it fit?
How do you know it still has a LSD ? It was a very rare option and even if it was delivered with one, is it still in residence? 20+ years is a long time in the life of a 'galvaniser' and many a LSD equipped E30 has had a 'safety conversion' along the way
- Tabbi
I know the previous owner had it checked and used to boast about the fact it had one even though he didnt have a clue about vehicle maintenance! I see what you are saying though. Im not sure whether it is the Diff, could it not be something to do with the Drive Shafts?
pony
- I have been misbehaving and am sorry !
Is this because LSDs are so desirable and therefore expensive ?pacerpete wrote:How do you know it still has a LSD ? It was a very rare option and even if it was delivered with one, is it still in residence? 20+ years is a long time in the life of a 'galvaniser' and many a LSD equipped E30 has had a 'safety conversion' along the way![]()
What do u make of Quaife LSDs are these better than BMW LSDs for going sideways ?
Quaife ATB diffs are great from what I've been told - I've driven one in a FWD car, but didn't give it real stick. If I got it right, they act like an open diff, but when needed transfer power/torque to where its needed - no inside wheels spinning up but also no locking across the axle. Not all that great for sideways action when compared to a clutch pack LSD.
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
Tabbi wrote:I know the previous owner had it checked and used to boast about the fact it had one even though he didnt have a clue about vehicle maintenance! I see what you are saying though. Im not sure whether it is the Diff, could it not be something to do with the Drive Shafts?
The only way to tell for sure is to jack it up and check. My money is on your mate imagining he had a LSD
You will soon find out when you investigate what is making the racket.
- Brianmoooore
The total working life of a new E30 type LSD can be measured in minutes. It's very unlikely that any LSD that's been on an E30 from the factory and hasn't been rebuilt is anything much more than an expensive open diff. by now.
Tabbi wrote:There is an 'S' on the diff which indicates it is an LSD. What can i replace it with?
Have you checked the diffs operation ? this will confirm whether it is actually a LSD and whether it is the source of your 'noise'
You can replace it with an open diff of a similar ratio . An IS has not got the power to make a LSD a must have.
The_Diddler
- Love it up the more door !
you could always do the "Drive it slightly side ways up a muddy slope until it reaches the top" trick and see which wheels spin or errr cough cough don't..................................pacerpete wrote:Tabbi wrote:There is an 'S' on the diff which indicates it is an LSD. What can i replace it with?
The_Diddler wrote:you could always do the "Drive it slightly side ways up a muddy slope until it reaches the top" trick and see which wheels spin or errr cough cough don't..................................pacerpete wrote:Tabbi wrote:There is an 'S' on the diff which indicates it is an LSD. What can i replace it with?
You can replace it with an open diff of a similar ratio . An IS has not got the power to make a LSD a must have.![]()
That does not tell you whether you have one or not, only that it is foooked
The_Diddler
pacerpete wrote:The_Diddler wrote:you could always do the "Drive it slightly side ways up a muddy slope until it reaches the top" trick and see which wheels spin or errr cough cough don't..................................pacerpete wrote:
- Tabbi
It only does it when i have a little steering lock on and it starts to jump and clunk. ive had all the shafts etc checked and they are not showing any signs of play. The 'mechanic' i took it to near my workplace reckons it is the snow. I mentioned it does it even on tarmac but his advice is to let the snow clear and then see. lol Unbelievable!
How can i check to see if it really is the Diff without going sideways anymore as that is what has buggered it! lol And do i need a small case/medium case one?
as Pete has said, buy a cheap open diff they normally sell £50ish on here.
then have your LSD rebuilt when money allows.
sure if you have a gander in the parts or put a wanted add up youl get one quick enough. unfortunately all the people i use for spares are down here in the midlands so cant recommend anyone.
have striped and repurbed my lsd diff myself changing all the bearings inside as i was unable to get any advice, i did some research and asked in some transmision shops for tips and all done nice and quiet too really not too hard if your handy with the spanners and have some engineering knowhow
gareth
Sorry for the delay chaps, I've been very busy with this new house of mine...
All PM's replied to.
hennared323i
Maybe you have a "drift spec" diffTabbi wrote:It only does it when i have a little steering lock on and it starts to jump and clunk. ive had all the shafts etc checked and they are not showing any signs of play. The 'mechanic' i took it to near my workplace reckons it is the snow. I mentioned it does it even on tarmac but his advice is to let the snow clear and then see. lol Unbelievable!
