Just read the local newspaper and an article on new MOT regulations testing 15 new things.surely these won apply to our cars?things like electronic handbrake
A noob question i know but does it mean we will fail if we don't have these additions?[/code]
new MOT regs
Lurch320i
macas
Yeah,id like to know these new regs,but in leahmans terms....
All of these things in the new regs. are followed by the words "if fitted", so don't worry.
There are actually some relaxations of the regs. that will be of more interest to some E30 owners.
- **BANNED**
In very simple terms,if the equipment(such as an electronic handbrake)is not fitted,then it cannot be tested,can it?
Youth is wasted on the young.
Lurch320i
It says
'new additions are now:
Electronic hamdbrake
electronic stability control to check steering during emergency stops or sharp bends
dashboard warning lights
steering and suspension including steering lock
subtle checks to headlight lenses
wiring and battery position within the engine
caravan electrical socket, to ensure indicators and brake lights work on trailered caravans work before being driven
built in tyre pressure monitors, which alert to slow punctures
airing warning light
speedometer
seat adjusters
doors - locks must be in working order
towbars
exhausts and catalytic converters working
fuel pipes'
speedometer
seat adjusters
towbars
fuel pipes'
Lurch320i
so does this mean if something isnt fitted anymore it can't be tested?like rear seatblets.or what if it wasn't fitted at the factory but is now like HID kits or newer engines that came with cats but are fitted without catsdaimlerman wrote:In very simple terms,if the equipment(such as an electronic handbrake)is not fitted,then it cannot be tested,can it?
Lurch320i
What are these relaxations you speak of?Brianmoooore wrote:All of these things in the new regs. are followed by the words "if fitted", so don't worry.
Rich320I
the dash board warning lights is a grey area, the mot guy failed mine on the brake light sensor being on even though it was due to the sensor not being fitted, the brakes were new. i did explain this but he was determined it was a fail?!
hennabm
^^No grey area - just the tester not understanding the written word.
The brake fluid warning lamp illuminated is a fail, not the pad wear sensor lamp.
The testers manual even advises the tester that the brake fluid lamp may be combined with pad wear or parking brake "on" warning lamp.
Relaxations include the ABS warning lamp sequence.
'82 323i henna
'10 116d Sport Red - MkI
'11 X3 3.0d SE
'89 240 DL Estate
'11 X3 3.0d SE
'89 240 DL Estate
Rich320I
i thought he was being a awkward, but i wanted to sort out the sensor anyway so i did.
it was a halfords test center though, he was so worried about the brake sensor light, he didn't even realise the horn didn't work
