Best engine oil for an m20
jonny323i
Post Mon Mar 25, 2013 6:45 pm
Iv read the zones wiki and im still not sure which engine oil to go for as i will be buying some soon and want to get the most benefit form the ecp 25-30% off on oil etc.
Normallly i would just go for castrol gtx 10w40 which i can get for £13.99 for 4l
But the zone wiki recomends a 5w40 fully synthetic. Iv seen mixed reviews on fully synth in an m20 and iv also seen the option for 10w60 or 15w50 which surely would give a greater range especially as m20s do like to run a little hot especially in summer (if we get one).
So what would you guys buy
Ps iv seen alot of people recently talking about using a diesel oil in the m20 whats that about
Touring for life
Post Mon Mar 25, 2013 7:03 pm
Diesel spec. oil in an E30 is just for a short time to clear sludge from the engine. Flushing oils can do more damage than good, as they can dislodge deposits of sludge that have been sitting in some corner of the engine for years, harming nothing, and allow the to flow into a bearing or somewhere else that sludge is not a good idea. Diesel spec. oil contains high levels of detergents, which can gently clean your engine.
A M20 in summer should run at exactly the same temperature in summer as it does in winter - the temperature stamped onto the thermostat. If yours runs hot, then a cooling system overhaul is in order, probably centred around a NEW radiator.
A 5W-40 full synthetic oil is the best oil for any M20 is good order, but that doesn't mean GTX 10W-40 isn't an adequate oil.
mr_dink
Post Mon Mar 25, 2013 7:05 pm
I'd say fully synth is overkill and I used 10w40 semi synth when I last had an e30.
The diesel oil thing was to do with noisy tappets on m40s I think, it was suggested that the extra detergents in diesel oil might help flush them out.
I don't think there is much difference in diesel vs petrol oil any more, it's often labelled as being for either.
Might be worth checking with other local motor factors if you have one, I paid £18.99 for 5l of Comma fully synthetic for my Audi.
jonny323i
Post Mon Mar 25, 2013 7:12 pm
Mine never goes above half way on temperature I just think m20s have a higher running temp than some other cars I'm used to.
So I can either be a cheap skate or spend a little more but both are as good
Touring for life
jonny323i
Touring for life
Ajsingh
Post Mon Mar 25, 2013 7:13 pm
Iv always used 10w40 castrol oil and it works perfect!
E30 Crazy!
maxfield
Post Mon Mar 25, 2013 7:19 pm
I used Motul 300v 10/40w on my last service, very expensive oil but it is a good oil. Probably overkill for an M20 mind.
andyp
True Old Skooler
Post Mon Mar 25, 2013 7:21 pm
ive used 10/40 gtx for years and its been great.
zaust
Zone day release
Post Mon Mar 25, 2013 7:48 pm
Depends on weather this is an early high comp or not and also hoe many miles on the lump.
M30 Tech 1 Touring on gas.
jonny323i
Post Mon Mar 25, 2013 7:50 pm
100,000 facelift low compression
Touring for life
Post Tue Mar 26, 2013 6:26 am
Think I've always used 10/40 or 15/50 in M20's - my rule is buy cheap but decent quality stuff and change it often with a genuine filter. Carlube or the Triple QX ECP stuff is fine and its cheap enough that you can change it every 6-12 months without breaking the bank.
zaust
Zone day release
Post Tue Mar 26, 2013 7:09 am
Ajsingh wrote:Iv always used 10w40 castrol oil and it works perfect!
My preference too. Castrol classic 10w 40. Or on a high miler 20w50.
or I run bardhal oil when I can. Same specs.
Chris_B86
Post Tue Mar 26, 2013 9:07 am
Mines always, (and I mean always from new) been run on Mobil1 5w40 fully synthetic. It's on 147k now and it runs sweet as a nut
Andyboy
Alpina Colada
Post Tue Mar 26, 2013 11:39 am
Mine is on 297'000 and has had a regular mineral or semi synthetic in the 10 years and 90'000 I've had it. I use a 10/40 grade. Before I had it, it was given whatever BMW recommend as it was a main dealer serviced car although it had a dealer oil change in Germany in April 2009. I would imagine 10/40 mineral or semi synth.
oomz1975
Post Tue Mar 26, 2013 7:49 pm
Been using Kendall 20w50, the touring loves it.
Change it every 6 months & engine is on approximately 150k miles.
HairyScreech
Post Tue Mar 26, 2013 8:02 pm
Any 10/40 semi synth will be more than up to the job on a stock m20, the bearing area vs the power produced is huge thus the bearings don't see a lot of pressure.
Post Tue Mar 26, 2013 9:12 pm
The oil recommended by BMW for UK conditions is 15W-50, but that is a quarter of a century out of date. 10w-40 is adequate, and will save fuel over a 15W/50.
Morat
Post Tue Mar 26, 2013 9:18 pm
It's amazing how little oil these engines burn compared with later models when you think we're running them on thinner oil than spec....
George
Post Wed Mar 27, 2013 1:53 am
I've always used 10w/40 Semi-synth, typically Castrol, either GTX or Magnatec.
I'm surprised that fully synth is recommended in the Wiki.
Post Wed Mar 27, 2013 9:44 am
Because it's an all round better oil. That doesn't mean that E30s won't survive quite happily on lesser oils.
Most of my fleet run on Shell Helix 5W-40 full synthetic, which cost me £3.88/litre, which is better value than any ECP promotion!
I buy this as a 5 litre can, bundled with a 2 litre free can, in French hypermarkets when I'm over there
Mo13
Post Wed Mar 27, 2013 11:25 am
thoughts on Triple QX oil?
jonny323i
Post Wed Mar 27, 2013 3:06 pm
That's the stuff I'm probably getting its £19.19 for 5l with a free oil filter at the moment from eco
Touring for life
Low_E30
Post Wed Mar 27, 2013 3:43 pm
One with a sell by date a apparently...
E30 BMW 325i Cabriolet M-tech1 + Hardtop
W201 Mercedes 190E 2.5-16
W124 Mercedes E220 AMG Cabriolet + Hardtop
S124 Mercedes Estate AMG
C126 Mercedes 500 SEC
W210 Mercedes E55 AMG (2001 Facelift)
Jaguar XJR Supercharged (2002)
jonny323i
Post Wed Mar 27, 2013 5:56 pm
Touring for life
Low_E30
Post Wed Mar 27, 2013 8:52 pm
jonny323i
Post Thu Mar 28, 2013 7:26 am
I'm sorry I havemt got the time to go through 6 pages :roll:
Touring for life
Low_E30
Post Thu Mar 28, 2013 9:50 am
No need to apologise, skip to page 4 half way down :D
