Post
Mon Mar 25, 2013 10:57 pm
Chip should be an easy pass, although in the swept area it's up in the sunstrip section so well out of the normal vision area.
Strictly speaking 'Band A' is a 290mm wide vertical strip centred in the middle of the steering wheel and it's top and bottom edges defined by the swept area, and damage more than 10mm diameter can be a reason for a fail.
It looks to me like the chip is far enough over to be out of band A
The crack is trickier, the visible bit is so close to the black band I would hope a tester would use their common sense and realise it doesnt impede your vision, but strictly speaking I think anything over 40mm is a fail, but there's a big difference between a golfball hit and a single thin crack!
cheers,
harry
