M52B28 with 3.0 bottom end components
Jacko_
Post Tue Mar 19, 2013 12:44 pm
Just wondering where people go to get piston rings, main and rod bearings from when doing the 3.0ltr crank rod and piston conversion?
I've picked up the main parts, but not sure on if oem or other components would be the best mix and what about arp bolts are these worthwhile?
I've heard lots of stories about people stripping the head bolt threads when removing the head, what can be done to minimise damage and how do you normally go about resolving this? I've heard of people using helicoil and also time cert - time cert kit is very expensive though!!
I had great ideas about headwork to make the most of my cams and itbs but costed it up to over £4k with solid lifters and upgraded everything so thought better of it s52 would be a much cheaper route.
Really interested to know what people have ended up spending in doing this conversion and where you bought parts and who did the work for you, I'm open to the idea of giving someone the parts and them building it for me.
E21 323i with 2.8 M52 on TBs (fast road / track car)
E28 M535i (track car project)
E36 328i touring (drift wagon daily driver)
penton08
Post Tue Mar 19, 2013 5:46 pm
I am in the middle of getting the bits together to do exactly the same, Danthe has quoted me to build it and his price is very reasonable :D Its all the other bits that send the budget skywards. I am sure I could get an s50 in and running for similar costs 8O
Jacko_
Post Wed Mar 20, 2013 8:10 am
Good to see more people doing it but do most stick with oem components or not?? Minefield or what!
randomspeedfreak
Post Wed Mar 20, 2013 10:52 am
im also interested in this. will be watching this post
BMW_E30vert
Post Sat Mar 23, 2013 4:59 pm
also interested, original mahle rings are about 60quid a cylinder from dealers where as i can get goetze rings for a 3rd of that is it really worth the extra going oem?
