Track/fast road 2013 built and tracked
Nato_e30
Tue Feb 05, 2013 2:33 pm
Cheers bud its got alittle out of hand tbh :$
Tue Feb 05, 2013 5:45 pm
Nato_e30 wrote:Yep :)
Just recieved these pics back from my pal at the powder coaters :)
I wasnt even being serious! :o
Will it hold up ok? I imagine it being on fire after some spirited driving :D
Nato_e30
Tue Feb 05, 2013 5:53 pm
Haha yeh itl hold up well, the lad who did my coating has done his on his track car :)
Another little update ive just fleeced and edged the other interior tidy up panel.
The weight of all these panels come in at 2kg
Nato_e30
Fri Feb 08, 2013 8:39 pm
So today ive dyed the mint cond dark blue carpet black and removed the thick heavy crap of the underside of it, also wet vax'd the sparcos and fitted a omp slider on the drivers seat
Before
After
Nato_e30
Sat Feb 09, 2013 5:57 pm
Today ive generally been giving the inside a good clean and sealing up areas that need sealing, ive also removed all the thick foam of the underside of the carpet to shed some wieght as im refitting a carpet in it.
Also ive sorted out the messy leaky sunroof blank
Before
I nipped down the scrappers and chopped a roof of a e36 so id have a neat profiled panel, measured and cut.
Edges filed and corners curved and etch primed
Tiger sealed and riveted into place
Perfect profile
Nato_e30
Sat Feb 09, 2013 10:48 pm
Refurbished throttle and blasted/ powder coated inlet :D
Nato_e30
Sun Feb 10, 2013 2:34 pm
Hard at work this morning, ive trimmed and fitted a fleece roof lining, alsstarted to reassemble the interior
Foam and sound deadening stripped of the underside of the carpet, so light now
Lining
Opologys for the crap pic quality its making all the black look grey. The dash has been a nightmare to fit, also the cage bolts are to big so ive gotto get some more so I can bolt it all in.
Rosc0PColtrane
Sun Feb 10, 2013 3:00 pm
That dash is lovely.
Sun Feb 10, 2013 3:29 pm
Nato_e30
Sat Feb 16, 2013 6:22 pm
Today ive ground the revets of the sunroof panel and prepped it to give a skim of body filler and refinish.
Ive fked about with a spoiler
Fitted the drop links to the arb
Better pic of the lining I made for the roof
Finished assembling the intake
Prettys :p
Nato_e30
Tue Feb 19, 2013 4:37 pm
Maf, jetted degreased and zink coated
Nato_e30
Sat Feb 23, 2013 6:41 pm
Starting refitting the underside, the rest will be undersealed when I get the front jacked up
All poly bushed+ adjustable camber rear beam
Nato_e30
Sun Feb 24, 2013 2:22 pm
Engine going back together complete new gaskets ect.. alot of tidying left todo still. Clutch fan binned off and slimline electric replacement fitted
Duke137
Sun Feb 24, 2013 2:29 pm
You might still make your deadline mate, it's looking good 8)
Nato_e30
Sun Feb 24, 2013 2:30 pm
Cheers dude im hoping I will :$ ive still got so much todo..
Nato_e30
Sun Feb 24, 2013 2:31 pm
Sun Feb 24, 2013 7:23 pm
:cool: :mad:
[youtube][/youtube]
Nato_e30
Sun Feb 24, 2013 8:10 pm
^ :cool:
initial_g
E30 Zone Moderator
E30 Zone Moderator
Tue Feb 26, 2013 10:57 pm
Wooo nanaged to log back in using my old username! :)
Tue Feb 26, 2013 11:19 pm
Is it done yet Graham :cool:
initial_g
E30 Zone Moderator
E30 Zone Moderator
Sat Mar 09, 2013 5:42 pm
Little update been very busy latley with work ect so have 6 weeks to finish it.... bearing in mind I only get sat/sun to work on it .. :?
Anyway ive refitted some of the engine up, im hoping to get the innerwings and afew other bits painted + the engine finished tomorrow, if tried fitting the rad with the new electric fan in but its too bulky so im relocting the rad slightly further forward.
initial_g
E30 Zone Moderator
E30 Zone Moderator
initial_g
E30 Zone Moderator
E30 Zone Moderator
Sun Mar 10, 2013 1:25 pm
Subaru impreza type ra roof flap.. installed and working :) bargain find a definate one off! Will keep the incar temps down incar.
Sun Mar 10, 2013 2:00 pm
Good find on the "Flap" Graham :cool:
initial_g
E30 Zone Moderator
E30 Zone Moderator
Sun Mar 10, 2013 9:52 pm
Cheers dude
initial_g
E30 Zone Moderator
E30 Zone Moderator
Mon Mar 18, 2013 3:29 pm
Update, got the sunroof blank finished, rivets ground off holes welded and a very thin skim of topstop gold and primed
initial_g
E30 Zone Moderator
E30 Zone Moderator
Mon Mar 18, 2013 3:33 pm
initial_g
E30 Zone Moderator
E30 Zone Moderator
Mon Mar 18, 2013 3:47 pm
initial_g
E30 Zone Moderator
E30 Zone Moderator
Mon Mar 18, 2013 9:41 pm
New bearings and bushes
initial_g
E30 Zone Moderator
E30 Zone Moderator
Mon Mar 25, 2013 1:35 pm
Snows let me down this weekend big time plus I wont get on it next weekend this projects not going well and ive majorly regreted starting it
Anyways with a major lack of enthusiasm ive got the interior panels rivited in and made some tidy up panels for the quarter panel this weekend..
Tedswagon
Mon Mar 25, 2013 7:07 pm
What you going to fix your harness to??
Mon Mar 25, 2013 7:22 pm
There is a bolt in harness bar by the looks of it
initial_g
E30 Zone Moderator
E30 Zone Moderator
Wed Mar 27, 2013 7:18 pm
Well spotted tedswagon, im making a harness bar to go between the wheel arches :)
Fri Mar 29, 2013 5:20 pm
Looking good dude :cool:
initial_g
E30 Zone Moderator
E30 Zone Moderator
Sat Apr 06, 2013 7:26 pm
Smashed it today
All hands on deck.. pete (psyko) did my welding and I got on with the mechanical
Replacement handbrake cables ,shoes, springs, pipe fiited all working and one side fully bolted up
