Clio III No Electrics
Hi guys,
Doing an oil change on somebody's Clio, and i've dropped a damn spanner through the engine bay and it's shorted on the alternator and an earth. Lots of sparks.
Now there are no electrics at all, APART from the central locking :S
When I turn the key there are definitely some noises, but no dash lights, no heater, no horn, no hazards etc etc.
Anybody have any ideas?!
Check all fuses would be a good start, and search the main battery cables for fusible links.
- **BANNED**
Bloody French shite.
Any petrol in the tank?
Youth is wasted on the young.
Oh well, better that than fried electrics, eh?
Whereabouts are they on Clios, and are they similar to BMW ones?
Interesting to know, thanks - my brother has a Clio Sport.
If you wanted to get it up and running while you wait for the replacement part to arrive, you could wire a suitable fuse across those two terminal posts.
To be fair, that sort of thing could happen on any car, and at least they thoughtfully put a fail-safe in place to prevent burnt-out electrics.
On older vehicles, it was common to disconnect a battery terminal prior to starting any work, but with modern cars with all the engine management, immobilisers, etc., people are afraid to do so in case it loses its settings!
They're not all bad. We replaced the front coil springs on my brother's, and it was a doddle. However, doing the cambelt and alternator wasn't quite so easy - the engines are really crammed in.
- Contact:
Your lucky Rix, they have a habit of setting off the airbags for stupidity like that, a local weirdo I know pretty much wrote of his mk3 clio when he hit a kerb due to swerving around a kamikaze taxi, dash airbag, seat airbags, seatbelt pre-tensioners and damaged wishbone, no more than 30mph
