Are power steering pumps swapable ?
smithy318i
will a PAS pump from a 316i fit a 325i ?
Zayyan
Yes
Martinaston
No
Different bracket and pipe layout
There is NO nucleus.
Zayyan
325i pump works with a 318i (same engine as 316i), can't see it not working in reverse.
If you're sure though
Martinaston
Same pressure but the M40 steering rack (ali) has a smaller pump with the pipes at a different angle to the old M20 one with the steel rack.
Bob_S
Martin aston is right the m20 pump is different to the m40 one.
Bollocks to this 24v scrap!
