Hi guys can you cost the following please,
Vin ac64462....
Rear panel,
the foam seals on heater box for where it bolts to the shell and also where the heater ducts sit on top of it.
The white wiring loom clips that secure loom to the inner sills under carpet
Then for a 318is m42 i need the following,
Price for 2 engine mounts
The gasket between oil filter housing and block
The bolts for the oil filter housing
And also the front crank seal in lower timing case
Thanks ian
multiple prices please
jonesy318
Any joy guys??
Cotswoldbmw
Hi There
Rear panel, £136.90 end of April into Germany
the foam seals on heater box £19.54 and £21.02 German order 3-5 working days
The white wiring loom clips £2.45 each German order 3-5 working days
2 engine mounts £124.22 for 2 German order 3-5 working days
The gasket between oil filter housing and block £3.16
The bolts for the oil filter housing - need to know if plastic or alloy housing
And also the front crank seal in lower timing case £22.14
Prices inc. E30Zone Discount and VAT delivered to mainland UK
Please call our Parts Dept. on 01242 257999 and quote 26069
There is a P&P cost of £1.99 on all orders under £20
Please remember if you require an urgent response drop our
Parts Department an email
partscheltenham@cotswoldgroup.com
Brett
Brett
Cotswold BMW Parts
01242 335365
PayPal? - No Problem
Just send the amount quoted as a gift to partscheltenham@cotswoldgroup.com, along with your name, reference number, delivery address and contact telephone number.
01242 335365
