OEM supplier for Rear Bushes and rear wheel bearings
appletree
Post Thu Mar 14, 2013 9:00 pm
Just wondered who made the originals or what people are using at the minute and from where.
Is it lemforda for the bushes and FAG for the bearings?
Matt
Grrrmachine
E30 Zone Wiki / Team Member
Post Thu Mar 14, 2013 9:25 pm
My bushes were a mixture of Lemforder, Meyle and Febi; all OEM standard, and just what the supplier had in stock at the time. No noticeable difference in quality.
Yes, FAG are the OEM bearing manufacturers.
capnmchl
Post Thu Mar 14, 2013 9:35 pm
Think SKF might of been an OEM supplier of bearings as well.
Post Fri Mar 15, 2013 12:56 pm
I would be fitting Lemforder beam bushes (same as BMW supplied but less than half price) ECP supply them, with bush fillers :wink:
Poly trailing arm bushes, ebay, I like these - http://www.ebay.co.uk/itm/BMW-E30-3-Ser ... 4d09dd0aa8
They are a single piece bush, most others seem to be in two half's which is unnecessary IMO
appletree
Post Fri Mar 15, 2013 6:51 pm
Thanks Dan, can you change your avatar back to the red and black one too :thumb:
