brembo swap
jamie-o-connell
hi lads just wondering is there any rite up on here showing whats needed fitting 7 series brembos onto a e30? i have the calipers and bracits already. btw i already did a search and couldnt find f all thanks
craigieeb
What exactly do you need to know mate?
If you have the calipers and brackets, just bolt them on to your struts over your larger discs...
M50 Turbo!!!
I shall say no more
jamie-o-connell
whitch discs suite the e38 calipers? ive heard280mm 22mm g60 corrado
discs with a bit of work. would this be right? thanks
jmc330i
Not a chance with 280mm discs. From memory you will need 302x28mm discs for those calipers.
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
craigieeb
You'll need a pair of these...
http://www.ebay.co.uk/itm/290368723148? ... 1423.l2649
with the center bore opened up by 1mm
And a set of either 16" or 17" wheels,
but.... there's not many sets of 16" wheels that fit over the brakes.
M50 Turbo!!!
I shall say no more
jmc330i
It says centre bore is 65mm for those discs, a standard 4 stud E30 is 57.1mm, so surely they're too big already??
Also, the OP would need to check that the brackets have been made with those discs in mind.
James
'91 325i Sport
'91 325i Sport
craigieeb
jmc330i
Could well be a typo, but worth checking before putting any money down.
Nice brakes though
What wheels you using to clear them? Any spacers?
Nice brakes though
James
'91 325i Sport
'91 325i Sport
craigieeb
I'm on a set of ebay special 16's, and had to use 5mm spacers,
finding a sort of reasonable set of 16's was just an absolute mission,
the spokes have to be on the "face of the wheel" so no lip,
the et had to be around 15-20
http://www.e30zone.net/modules.php?name ... ght=brembo
i'm sort of swaying back towards 17's again now,
as i need wider wheels to get some sort of grip
M50 Turbo!!!
I shall say no more
