Vernier Pulley for M20B28
Kedge
Post Fri Mar 01, 2013 2:45 pm
Guys,
Can anyone recommend a quality vernier pulley for my M20B28 engine build.
Cheers,
Instagram - Kedge85
maggspower
Turbo Farmer Tractor Driver
Post Fri Mar 01, 2013 2:54 pm
Kent do a good one. About £155. Larkspeed Leeds, can get hold of them.
I can get hold of them direct from Kent a little bit cheaper if a few people want them.
Ebay is flooded with rubbish ones at the moment, cheap but I wouldn't trust them.
Kedge
Post Fri Mar 01, 2013 3:03 pm
Dan said he'd looked on eBay and they all looked crap. A quick Google didn't bring much up either.
Is there any others to chose from?
Instagram - Kedge85
Post Fri Mar 01, 2013 5:15 pm
Ive seen pics of Turner Motorsport ones that look nice but I expect they cost even more
Kedge
Post Fri Mar 01, 2013 5:57 pm
Can't find anything on their website for one. I've e-mailed CatCams to see whether they have anything. Can't think of anyone else so might have to be the Kent one, Larkspeed seem to be the only ones selling them.
Instagram - Kedge85
maggspower
Post Fri Mar 01, 2013 6:06 pm
Vac motorsport USA have a nice offering but its expensive + import duty.
reggid
Post Fri Mar 01, 2013 11:05 pm
nuke
E30 325is with M20B31
HairyScreech
Post Mon Mar 04, 2013 1:40 am
I have been told to beware of some of the ones available online, they are made with the tooth pitch slightly off/the pulley is slightly too big.
It was certainly the cheepo blue ebay ones but i'm not sure which others fall into that trap as well.
If buying one then either go for a known good one or make sure it is returnable.
Kedge
Post Mon Mar 04, 2013 2:47 pm
Well I'm certainly staying away from the eBay specials.
It's either going to be the Kent or Catcams, the Catcams is about £20 cheaper. Discounted the Nuke since it'd need importing, making any issues that may arise a pain to sort out.
Anyone got any experience of the Catcams or the Kent pulley?
Instagram - Kedge85
gooner1
Out humping Reindeer
Post Mon Mar 04, 2013 4:00 pm
No zoner willing to lend you or Dan one, Dave?
Kedge
Post Mon Mar 04, 2013 6:49 pm
Wouldn't be worth it Rob, I'll need one regardless so best to get one now so it's all set in the correct position from the off.
Instagram - Kedge85
Bullet_Ride
Post Tue Mar 12, 2013 7:45 pm
I made one for my 2.8L M20 last year. If you know a shop that can laser cut you some 3/16" plate you can make your own fairly cheaply using the stock pulley.
The idea behind the spacing on the holes on either side of the spoke was for setting the timing by simply sticking a dowel pin in the hole and rotating until it contacts the spoke. As you can see on the top spoke the holes are touching, that's for setting back to stock timing, then each consecutive spoke the holes are spaced 1 degree further apart. So I have +/- 5 degrees of adjustment on the cam pulley and since it's 2:1 ratio to the pulley on the crank it's really +/- 10 degrees (in 2 degree increments).
I can email the CAD file to anyone who's interested.
Post Tue Mar 12, 2013 8:02 pm
Top job that! Dave, send it back, we have a new plan :D
HairyScreech
Post Tue Mar 12, 2013 8:14 pm
Saw that when you posted it on another forum, thought it looked like a good job then and now its on the engine is looks even better.
Go with that kedge, at least you know your getting a well made pulley.
Bullet_Ride
Post Tue Mar 12, 2013 8:31 pm
HairyScreech wrote:Saw that when you posted it on another forum, thought it looked like a good job then and now its on the engine is looks even better.
Well you can't really see it since I'm running the stock dizzy still :P
Once I finish my ITB project the next project will likely be converting my MS to wasted spark so that I can get rid of the stock dizzy and show off my timing pulley :)
Kedge
Post Tue Mar 12, 2013 8:46 pm
DanThe wrote:Top job that! Dave, send it back, we have a new plan :D
Awesome, that looks like a good quality pulley! :cool:
Dan, checked my e-mails and I've had no dispatch notice (feckers have had my money a week now) for the vernier so sent them a mail telling them to cancel the order, will call them in the morning to make sure.
Instagram - Kedge85
