Measuring Coolant Temp
Grrrmachine
E30 Zone Wiki / Team Member
Mon Mar 11, 2013 10:31 am
I'm trying to configure my data-logger to read actual coolant temp in degrees, but using the original brown temp sensor in the head.
I understand I need to know what the resistance of the brown sensor is at a given temp, but how do I work out what the temp of the coolant is? I can't just stick a thermometer in the coolant tank.
Any ideas?
Karan
Mon Mar 11, 2013 10:35 am
Take sensor out, stick in boiling water-100degC, then tell datalogger that resistance at that point equals 100
Grrrmachine
Mon Mar 11, 2013 2:58 pm
Trouble is knowing what temp the water is :D Most thermometers don't go to 100 degrees.
I'm going to have to rig up a saucepan with the brown temp sensor AND an oil temp sensor in, connected to a gauge, and do it that way. Pics to follow :D
Karan
Mon Mar 11, 2013 2:59 pm
Well the water will boil at 100..... I don't understand what u mean
Grrrmachine
Mon Mar 11, 2013 3:48 pm
Knowing when the sensor is at 100 degrees won't tell me what it reads at 60, 80 or 120 degrees. Considering the dash clocks only cover about 80-90 degrees, I need more points to measure the range.
capnmchl
Why not take it at a more sensible temperature then?
I don't know how a data-logger works, but surely it needs the difference in resistance for an interval of 1 degree rather than the resistance at an arbitrary temperature?
As long as it's a linear sensor, then taking the temperature at 20 degree and 40 degrees, and dividing the difference by 20 gives you the different in resistance for one degree, and adding (or subtracting) that from a base resistance at a known temperature can give you the resistance at any temperature?
Saves you burning yourself as well.
Grrrmachine
Mon Mar 11, 2013 4:04 pm
capnmchl wrote: As long as it's a linear sensor...
That's the key. Pretty much any thermistor is non-linear, especially automotive ones (considering the temps they work at). Otherwise I'd have done what you said yonks ago.
I've got all the readings for the blue temp sensor, so I'm going to stick them both in a saucepan and watch how their resistances change.
Karan
Mon Mar 11, 2013 4:06 pm
:mad:
I see what u mean now
Grrrmachine
Mon Mar 11, 2013 4:44 pm
This was the concept :D
I just needed a gauge that read 50-120 rather than 60-170 :mad:
**BANNED**
Mon Mar 11, 2013 5:06 pm
Grrrmachine wrote:This was the concept :D
You either have a very understanding 'er indoors or are hung like a porn star!
I hope that you remove all oily paw marks from the kitchen....
Grrrmachine
Mon Mar 11, 2013 5:18 pm
daimlerman wrote:You either have a very understanding 'er indoors or are hung like a porn star!
I'll let you decide on that one winkeye
suedenim
Mon Mar 11, 2013 5:24 pm
Grrrmachine wrote:Trouble is knowing what temp the water is :D Most thermometers don't go to 100 degrees.
Try looking for a cooking thermometer rather than a weather one:
http://www.lakeland.co.uk/8776/Preservi ... tAod7SsASw
1982 E21 316 Baltic Blau
1989 318i 2 Door Sterling Silber
Feedback: http://www.e30zone.net/modules.php?name ... highlight=
gromgsxr
Mon Mar 11, 2013 7:07 pm
Think if got a data sheet for the ecu blue sensor with resistance at diff temps if that will help
Grrrmachine
Mon Mar 11, 2013 8:38 pm
It's alright, I'm all sorted now. I had a coolant sensor table that turned out to be for the brown sensor, so that's all coded in now (it's a logarithmic formula) so that I'll have a really accurate temp gauge rather than just "above blue, below red".
At the moment the data logger will look like this:
Just need to code the Tacho, Speedo and oil pressure now :D
gromgsxr
Mon Mar 11, 2013 10:25 pm
I'm using ms3 and shadow dash connected via blue tooth to ecu so dash is on a 7 inch tablet that has speed gear mpg afr water temp air temp ect its pretty cool, the speed signal is a 5v square wave with 9 pulse per rev if you take it after its been through the spedo custer
Grrrmachine
Tue Mar 12, 2013 5:03 am
That speed signal is very useful, thanks for that. How did you get it to detect the gears though?
gromgsxr
Tue Mar 12, 2013 8:59 am
the gear is calculated off road speed and engine speed, i put in the diff ratio and the ratios of the gears wheel diameter how many pulses per rev of wheel and my ecu works it out
Grrrmachine
Tue Mar 12, 2013 1:03 pm
That's sneaky! I like that!
This thing is a programmable unit, so once I've calibrated all my sensors I can do whatever I want with it, as long as I can work out the logic. But I'm using the original Motronic 1.3, so there won't be any actual modification of engine parameters; it'll be a glorified OBC effectively.
Have you got any idea how the econometer/ injector pulse is calculated? I need that for fuel rate/mpg calculations.
gromgsxr
Tue Mar 12, 2013 2:01 pm
i connected the fuel flow that would have come out of the stock motronic to one of my injectors switched earth from megasquirt im fully sequential so that would be 1 injection event per engine cycle 720 deg crank rotation, motronic is batch fire injection im assuming that it fires the both banks alternating eg 1,3,5 bank one then 2,4,6 bank 2 360 deg late, i believe its connected to one of the banks so still gives 1 injection event per cycle. my econometer agrees with what i get on the computer from the ecu within 2mpg.
gromgsxr
Tue Mar 12, 2013 2:47 pm
i believe tacho is a square wave as well on facelift cars, what is the logger/software you using out of curiosity?
Grrrmachine
Tue Mar 12, 2013 4:35 pm
It's not anything. The input/outboard board is called a Fusion Brain; it's got 15 analogue inputs and 31 digital outputs. I'm using the software that comes with it, which is based on C# in a .NET environment. I've got it running on a Windows laptop, and you can see the built-in screen in the link in my signature.
I need to build a few frequency-to-voltage converters to get some readings off speedo and tacho, then I'll examine the fuel rate. I've just tapped into the wires coming out of the cluster, so there's no interfering with the ECU.
Demlotcrew
Tue Mar 12, 2013 4:41 pm
Im pretty sure the OBC calculates MPG from injector duty cycles?
gromgsxr
Tue Mar 12, 2013 4:53 pm
ok thats pretty cool has everything got to be in an analogue form, say for speed 0v would = not moving and 5v = max speed say?
Demlotcrew
Tue Mar 12, 2013 4:59 pm
I would have to dig through all my documents, Just cant remember :(
gromgsxr
Tue Mar 12, 2013 5:20 pm
yeah id say so my obc fuel input is connected to a injector now
Grrrmachine
Tue Mar 12, 2013 5:33 pm
Completely depends how you write the code, but yes, it all depends on input voltage. This one works on 0-3.3V with 1024 bits resolution, so you can just write "input > 0 = ON" as a basic idea. Because it's 3.3V I have to use a load of voltage dividers to bring all the signals in line, but that's no big drama.
Andy, knowing how the OBC calculates MPG would be useful, cos at the moment I'm using the econometer signal rather than the injectors themselves so I have no idea what the ECU is outputting there.
Tue Mar 12, 2013 6:43 pm
OBC uses the pulse width and frequency of the injector feeds to calculate fuel used, then divides this by the road speed signal from the yellow (also available at the green) socket on the instrument cluster.
gromgsxr
Thu Mar 14, 2013 6:08 pm
Will you be doing anything with fuel level? Was playing with my obc today and realised it has how many liters are in tank, I would assume this it fed down from the clocks to the obc? Anyone have any info on this I assume it varies the resistance according to the fuel level?
Grrrmachine
Thu Mar 14, 2013 6:24 pm
Depending on which tank you have, resistance runs from 60 Ohms (55L) or 120 Ohms (63L) down to 0 Ohms.
It's a linear drop so there's no fancy formula to it. Again, I took a wire from the back of the clocks.
If you want to tap into the instrument wires, it's these ones:
Speedo- pin 26 of the yellow connector, or pin 1 of the green connector (brown/red of yellow plug to obc green plug)
fuel level- pin4 white plug (BR/GN) or pin 6 yellow plug (BR/GN) to pin 16 OBC
coolant temp- pin26 blue plug (BR/VI)
Tacho - pin7 blue plug (BK)
fuel rate - pin31 blue plug (YL/WT) or pin25 yellow plug (WT/BU)
Outside air temp - Pin 2 green plug on OBC (BU)
If you're using BMW's wiring diagrams, then:
blue plug - C1
white plug - C2
yellow plug - C3
gromgsxr
Thu Mar 14, 2013 6:32 pm
Il have to look in to this that's the only thing I can't log or see on my tuning software / display iv got a few spare inputs to play with
Grrrmachine
Sat Mar 16, 2013 1:47 pm
Got a problem :cry:
As soon as I plug in the wire coming from the Tacho, both the tacho gauge and econometer go dead. I've used pin 7 from the blue plug, going into a frequency-to-voltage converter. I guess the gauges don't like it.
Any ideas?
Sat Mar 16, 2013 2:36 pm
Use a transistor in an emitter follower arrangement as a buffer, or even simpler, just try including a resistor in the wire.
Grrrmachine
Sat Mar 16, 2013 5:56 pm
Thanks Brian, a simple 1k resistor sorted that out. I've also got volts coming through from the econometer now, but I need to run some live tests to make sure they're related to the movement of the eco needle.
I now need to sort out the speedo, but I'm not getting a signal out of the yellow plug, so I'll have to tap into the green one that feeds the cruise control... which has never worked. Hmmm.
Grrrmachine
Sun Mar 17, 2013 12:46 pm
You win some, you lose some.
I got my calculations wrong for the coolant and oil temp, so I'll have to start again on that one. I've managed to access the Tacho now, and that's sending out a steady linear signal too. Fuel gauge is accurate, and I've got raw voltages for the oil pressure and fuel rate that I can decipher later.
But I'm having a real problem with the speedo. Absolutely nothing coming out that I can detect with my frequency-to-voltage converters, and I don't have access to an oscilloscope. The speedo on the cluster works, and I'm getting continuity between the OBC plug pin (yellow plug on the cluster) and the green plug that feeds the cruise control, but no signal to my data logger.
As grom said, it should be chucking out a square wave - any idea what basic tools I can measure that with aside from an oscilloscope?
gromgsxr
Sun Mar 17, 2013 1:54 pm
Iv got a small digital storage scope so can scope stuff if you need.
