WANNA MAKE MY E30 325I A 335I M5 ENGINE!!
hass
HI EVERY1 I WANNA MAKE MY 325I A 335I I HAVE LOCATED AN ENGINE OUT OF A OLD 5 SERIES M5 AND I WANNA KNOW WHATS INVOVED IN THE ENGINE TRANSPLANT?WILL I HAVE TO GET ENGINE MOUNTS MADE UP?WILL I HAVE TO CHANGE MY WIRING LOOM AND ECU?
WHAT OTHER MAGER THINGS WILL I HAVE TODO?
IF ANY1 CAN HELP ME ILL BE VRY GREATFULL.
THANXS HASS
THANXS HASS
nav786
you will need:
engine, box, ecu and complete wiring loom
custom prop
Diff
Rad ( not sure if m5 one works)
probably missed lots of small bits that you need out. Speak to Karan as he is doing this conversion.
custom prop
Diff
FOR SALE
SONY PSP'S £100
fuzzy
wont an e30 lsd handle that?
hass
carnt i use the e30 dogleg gaerbox?
is there a way i can use my original loom and ecu wont it run the engine?
hass
whos karan?
Pilsbury
Is this a picture of your keyboard?
Andy335Touring
If you use the dog leg box i think you will need an M3 dif, the ratio is 3.25
Karan is using the later 3.6 M5 engine from the E34.
Try using this page http://babelfish.altavista.com/ to translate this page http://www.e30.de/m335i.htm for more info on the swap
hass
thanxs for your help mate i appristate your help
charlE30
For the section on the 335, you don't need a translator. They've put an engligh buttonAndy335Touring wrote:If you use the dog leg box i think you will need an M3 dif, the ratio is 3.25
Good luck with the conversion hass, just about to start mine
BMW E30 344i track car
BMW F31 335d xdrive
BMW F31 335d xdrive
Chaos
one of the members on here who is doing a similar conversion.hass wrote:whos karan?
Chaos
causing havoc and mayhem wherever i go
Steviec
Took me a minute to get the joke! Im a bit slow today. lolPilsbury wrote:Is this a picture of your keyboard?
Toby_Unna
- Boost Junkie
he's on about the M335i page not the 335i pagecharlE30 wrote:For the section on the 335, you don't need a translator. They've put an engligh buttonAndy335Touring wrote:If you use the dog leg box i think you will need an M3 dif, the ratio is 3.25
charlE30
Toby_Unna wrote:he's on about the M335i page not the 335i pagecharlE30 wrote:For the section on the 335, you don't need a translator. They've put an engligh buttonAndy335Touring wrote:If you use the dog leg box i think you will need an M3 dif, the ratio is 3.25
BMW F31 335d xdrive
BMW F31 335d xdrive
