REV COUNTER problem - takes a while to start working
Zayyan
Post Tue Dec 27, 2005 6:33 am
Got a rev counter problem which is that it sometimes (more often than not) doesn't come on when the engine is started but instead takes a while to wake up (has be anything from 2 seconds to 15 minutes so far).
Does anybody know what the problem is?
Car is a 1993 318i M40 if that matters.
Don't really want to change the clocks as it doesn't bother me that much but if it's an easy fix....
Thanks in advance :)
Post Tue Dec 27, 2005 10:32 am
I would unplug and reconnect the C101 engine loom connector on the bulkhead a few times as a first try.
Mops
Post Tue Dec 27, 2005 7:57 pm
Brianmoooore wrote:I would unplug and reconnect the C101 engine loom connector on the bulkhead a few times as a first try.
you may do the same with your ECU connector.
Get an alectrical contract cleaner and spray both those connectors well.
1985/E30/325i coupe/5 speed/125k miles/shortshift/megasquirt II ECU controlling fuel and spark with custom ignitor and ICV mods/LC-1 wbo2/collecting parts for FI
Zayyan
Post Fri Dec 30, 2005 3:57 am
Thank you chaps, this appears to have worked :banana:
Post Fri Dec 30, 2005 9:53 am
Zayyan wrote:Thank you chaps, this appears to have worked :banana:
C101 doesn't seem to suffer corrosion problems generally, but the tacho signal seems to be exceptionally sensitive to the slightest poor connection here.
