ATE or Girling Front Brake Caliper Replacement
newportimports
Post Fri Mar 08, 2013 5:18 pm
HI
I want to get new front calipers but have been advised that there are 2 different caliper manufactures for my year (1990 E30 320i 2door), either Girling or ATE.
My question is does it matter which ones I buy? Are the front caliper carriers the same for both manufactures?
I have read on the E30 zone wiki that the pads are the same but it doesnt reference the calipers themselves?
1 brand is more ££s than the other as well, so I assume they are different but in what way.
I have tried to see what part numbers are on my calipers but they are corroded and its difficult to see any numbers on them?
bmw_325i
Post Fri Mar 08, 2013 5:34 pm
The calipers are different, as can be seen when when comparing these 2 diagrams:
ATE:
http://bmwfans.info/parts/catalog/E30/4 ... _sensor-2/
Girling:
http://bmwfans.info/parts/catalog/E30/4 ... ad_sensor/
The most obvious visual difference is that the Girlings have a guiding pin at top and bottom with a small rubber dust cover.
Jozi
Post Fri Mar 08, 2013 8:41 pm
Would you refurb your own callipers? You can get a seal kit from Biggred and use something like bilthamber deox-c or electrolyses to de-rust them.
milescook
Post Fri Mar 08, 2013 11:22 pm
The caliper carriers are also different so you cant mix carrier types with different calipers.
Also please help the race budget by watching some videos :) https://www.youtube.com/cookracinguk
newportimports
Post Mon Mar 11, 2013 2:43 pm
Thanks people!
I have found my are the Girling style thanks to "BMW_325i" members helpful links.
bmw_325i
Post Wed Mar 13, 2013 2:03 pm
:thumb:
