New radiator - Auto to manual & removed air con...
Kemlo
Post Thu Feb 28, 2013 12:54 pm
Hi,
Finally planning to get my car back on the rood after it's been laid up for a good 15 months!
I suspect I may need a new radiator, but the car was an automatic, and it used to have dealer fit air con (removed when the transmission was changed).
I'm happy enough that I can replace the radiator with an auto one, but does the fact that the car used to have Air con make any difference or can I just disregard that fact?
Grrrmachine
E30 Zone Wiki / Team Member
Post Thu Feb 28, 2013 2:05 pm
The difference is in the boss that allows a temp sensor to be fitted to the radiator; aircon rads need it, non-aircon rads don't always have it. If your aircon is removed then it won't make any difference.
Kemlo
Post Thu Feb 28, 2013 2:27 pm
Grrrmachine wrote:The difference is in the boss that allows a temp sensor to be fitted to the radiator; aircon rads need it, non-aircon rads don't always have it. If your aircon is removed then it won't make any difference.
Thanks man, much appreciated.
